346 OE intermittent bog, won't reach 13k RPM, Revisited FIXED!!!
decableguy2000
6:06 AM
WNC
For some inquiring minds, including mine
Aftermarket base gasket might need some trimming to match transfers better
I can’t help but wonder now if the flywheel has slipped.
Doesn't appear to have.
Piston not 100%, but IMHO should be fine with new ring, ring end gap .002
XP_Slinger
They’re Just Saws
6:06 AM
Central NY
I would be very surprised if that gasket is causing the problem. That Chinese carb would be my suspect. Did you pull Welch plugs and see if there was debris blocking the main jet passage? I know you’ve swapped carbs and stuff but I think we’re all running out of steam on this one.
decableguy2000
6:06 AM
WNC
All the Zama's are Chinese that I know of. Going to try to swap the whole tank form the 351 to this one, just for giggles.
decableguy2000
6:06 AM
WNC
Going on the back burner until I get a new carb mounting flange, screw is starting to strip out, and I managed to break a starter pawl.
cus_deluxe
terms of service violator
6:06 AM
Michigan
Sounds like junk, i can help you out with it :cool:
XP_Slinger
They’re Just Saws
6:06 AM
Central NY
Dammit you’re right. Was thinking you had a walbro, I think I need to shut up for today lol
