PogoInTheWoods
- 6:51 PM
- Apr 23, 2016
- Ohio
Agreed on compression not being the problem here. And a bad tank vent wouldn't make it run richer, it would starve it. That said, I'd like to see pics of the 'vent' location and how the vent is actually installed just for grins since there were a couple tank variations and vent orientations among these saws..., and there is the purge (primer?) bulb in the mix. And no one has mentioned the throttle linkage as a possible source of the RPM limitation, though being able to run this saw with the 'H' screw all the way in is a whole other issue to contemplate. I do believe I'd also try to find yet another coil to try for an additional comparison there.
As an aside, there's a reason these saws have a decomp, and 140psi ain't it. If my stock NE346xp was only blowing 140-ish, I'd be tearing it down to find out why (after grabbing another compression gauge to actually confirm such a reading). I'd also respectfully suggest that leaky decomp valves and plug seats are often as much to blame for lower than expected compression as carbon buildup or oil residue is for higher than 'normal' readings. It's not normally to the same extent, but can still be a factor. Not trying to be contentious here, just offering a personal observation based on a certain level of experience..., mostly gained by learning things the hard way in the first place. LOL
