288 Piston in a 660
Brewz
5:25 PM
Hunter Valley - Australia
Thanks for the reply. Wanted to try one for myself.
I’ve heard it’s a lot of work for not much more gain. I’m only at 65% bore width on the exhaust, which is where many take their builds without a lot of short circuiting. In addition, I’m right on the edge of the stock piston‘s skirt, I probably coulda gotten away with it, especially with a the winged skirt type slug.
I didnt do fingers, hard to make them not just push the flow circuit back towards the exhaust. I am making sure to have at least 40-45* of case compression and to keep the transfers as tight as possible to prevent short circuiting. In addition, opening the transfers at the ex side first gives them a better chance to push charge away from the exhaust.
The piston is already lighter than an 066 one. And it’s gonna lose even more weight when I clean up the casting flash and add a 395 pin.
As for the exhaust, I always do rearward placed side exhausts. Front openings don’t allow the sounds waves to collide and cancel each other out. It’s just loud without a lot of gain.
Guess I’ll see if the lemon was worth the squeeze.
use a tapered 880 pin and grind it to length.
The husky pins are thicker and heavier
2:25 AM
Ain’t got one. Piston and pin are currently lighter than the stock OEM 660 piston and pin. I may bore out the meteor pin. It’s super thick.
I’ll post pics when I get there.
Brewz
5:25 PM
Don't have one...... Stihl shops sell them haha
Only gets you a couple grams.
Not really important unless you are chasing every last bit.
2:25 AM
Got a few hours in on the saw. Rough time of the year.
This saw, which was supposed to be all OEM came to me with a load of AM parts. They make the work 6 times as hard to do. I have to search my parts bins for brake parts and redo most of what I did yesterday at this point. Plastic covers I generally use, but usually nothing else. The brake assembly cover is warped, or is cast wrong and hits the spring.
PHOTO-2023-06-25-11-13-23.jpegPHOTO-2023-06-24-14-24-59.jpegPHOTO-2023-06-25-11-13-27.jpegPHOTO-2023-06-25-11-16-55.jpegPHOTO-2023-06-25-11-36-08.jpeg
2:25 AM
Best oil cap I could find. Upon first fueling, I remembered that new oem tanks don’t include fuel filters, luckily had one.
Gonna run a few tanks through her, then she’s heading to the new owner after a detour to Red97.
PHOTO-2023-07-04-13-03-59.jpegPHOTO-2023-07-04-13-10-30.jpegPHOTO-2023-07-04-13-29-59.jpegPHOTO-2023-07-04-15-50-23.jpegPHOTO-2023-07-04-15-55-10.jpeg
Powerstroke Cowboy
12:25 AM
Montana
Very nice build! If you don't mind. What color and type of paint did you use for the crankcase?
NateSaw
2:25 AM
Maryland, USA
Immaculate work doc💪👍
Things gonna be IGNORANT when the rings seat.
