262 rebuild
paragonbuilder
2:53 AM
Norwich, CT
Never did check squish yet but my final numbers are
103.5
119
72
Hopefully that works, I'll post some pics later and as I go.
If you're planning to delete the gasket, make sure you check the squish, they tend to be .010 or less
wcorey
2:53 AM
ma usa
So I have read lots of different options on transfer height anywhere for 116- 126 is there a go to number or is that up for debate?
It's more the blowdown number that dictates transfer height and that's relative to the exhaust height.
The amount of blowndown is up for debate/experimentation, usually 17-20 or there abouts so you're a bit tight but should be ok.
2:53 AM
Check your squish.
Sand your band with an old piston till it's 20 with no gasket.
Make a .020 popup.
Drop jug over it until squish 20 again.
Relieve the intake skirt till it makes the intake around 76-78.
And don't fark with those transfer tunnels too much. The work of art in the great jugs is right there. It takes a lot of time and practice to touch up the Mona Lisa and make it look better, if you catch my drift.
BTW, how are you measuring your transfer height? If you're looking through a port or the plug hole only, that's just a rough guesstimate of where to stop your degree wheel with a ring placed in the bore. The only accurate way is with a ring pushed up by the piston and a pic to feel where the transfer is opening.
If you want/need the base of your jug cut, I'll do it for nothing. Just pay shipping.
104/120/76-8 are very good numbers for a 262 IMHO. I bet you're happy.
Johnmn
1:53 AM
Minnesota
Anyone seen this before I have a meteor piston ( same height as oem) and my ks cylinder and I have .019 squish with no gasket I checked several times because of what everyone says they should be. Seems my squish and timing are a bit different than normal.
Johnmn
1:53 AM
Minnesota
Timing with no gasket
105
122
70
Tor R
Novice, Leg model #2
8:53 AM
Mandal
My KS was around 0.009" without gasket (meteor piston), and those Mahles I got is very similuary in squish, I used Plastigauge when I did squish test.
My experience with soldier is that if they isnt soft enough they give a false reading, around 0.003-4"
Johnmn
1:53 AM
Minnesota
This project has been put on the back burner. Messed around with the cylinder some more last night ended up at
104
123
73
I put the cylinder on and am gonna try it
XP_Slinger
They’re Just Saws
2:53 AM
Central NY
104
123
73
Intake at 73* makes more sense without the BG. My brain back fired when I red that you lost intake timing with the gasket removed.
Johnmn
1:53 AM
Minnesota
I revamped my degree wheel I think my original stock numbers may have been off a little. But now with the drill chuck it's much better
XP_Slinger
They’re Just Saws
2:53 AM
Central NY
Good deal. Never good to have your degree wheel lying to ya, could send a good cylinder right down the crapper. Glad you got it dialed in.
Johnmn
1:53 AM
Minnesota
Well I finally got this saw together and it won't run at least very good. It has a new carb kit, saw it just super pig rich. Metering arm? Any thoughts would be great!
Johnmn
1:53 AM
Minnesota
Maybe I didn't get something right with needle and seat. Turning h & L screws do nothing just dumping fuel. I'm wondering if the needle is no seating and is just allowing fuel to just dump in? I don't know just thinking
