254/346 Hybrid Build “documentation” thread thingy… idk
ZukiRyder440
Breaker of recoils
7:37 PM
NY
I ordered the piston, it should be here this upcoming Wednesday and ill start tearing it down for machine work/ port work.
So far its real promising. Im curious to see how it stacks up with a stock 254
ZukiRyder440
Breaker of recoils
7:37 PM
NY
Ooops i forgot last night heres some measurements too. I just might be able to ditch my spacer, we shall see
ZukiRyder440
Breaker of recoils
7:37 PM
NY
I replaced the started pawls, the old ones were fooookkeedddd. Luckily fhe 266/268/272 pawl are a perfect fit. Gotta love a 2 series👍🏻
ZukiRyder440
Breaker of recoils
7:37 PM
NY
The corners were rounded off on the pulley so I took a grinder and made those edges straight, came out pretty decent. Itll get a saw started I suppose
ZukiRyder440
Breaker of recoils
7:37 PM
NY
It ran.. briefly… it acted like it was sucking air. The transfer tunnels I ground on had a hairline crack and sure enough it opened up into a giant hole… so i filled it and am not in the process of spinning the flywheel on the lathe to clear the bulge.. bonehead move.
ZukiRyder440
Breaker of recoils
7:37 PM
NY
While it was apart, I did some mild port work, I widened the ex and in and tried to fix the shape of the lowers. They were all sorts of wonky to say the least
ZukiRyder440
Breaker of recoils
7:37 PM
NY
Top of the piston was machined down flat, it curved up to .010” towards the combustion chamber then tapered off to .0245” down at the edge of the band closest to the cylinder wall.
ZukiRyder440
Breaker of recoils
7:37 PM
NY
Stock ex width in the middle, widened are the out side marks of course. Did not do anything in terms of tweaking port timing/ duration. Just added more area.
