Adirondackstihl
- 1:50 AM
- Dec 4, 2015
- Upstate NY
Don't know bout thatHusqy has the 50cc locked down hands down
I wouldnt let your 550 watch this if i were you. Might have nightmares.Ive had a ported 241c, ported 261, ported 026, ported 262,and a ported 362c. Id take this stock MM 550xp over all them
Think a 261c will give the 550 a go?Don't know bout that
Looks great! My 262 cut about the sameI wouldnt let your 550 watch this if i were you. Might have nightmares.
Depends on what you're looking for, but I wasn't thinking about a 261.Think a 261c will give the 550 a go?
Ive never ran a 5100. Only Dolmars ive ran was a stock 6100 and a MillerModded 7910. That 7910 was awesome!!Depends on what you're looking for, but I wasn't thinking about a 261.
I honestly think a 5100S has it beat in the power department.
Does it spool up like a 550? No.
But who's cuttin clouds
I agree with you in some of your points.The 242 is a fast saw in small wood. Rapid acceleration, high no load rpm, but not much torque. Was not designed to be anything else. A stock 353 will murder it. I had two 242xp's one new and one very low hr mint. It got its legendary status from it's advertised no load rpm. Put it in more the 4" wod and the rpms drop way down.
I told you, you would be doomed when you got the 550!Ive had a ported 241c, ported 261, ported 026, ported 262,and a ported 362c. Id take this stock MM 550xp over all them
This is th truth. That 550 i used was smooooth. Thats what i miss about my 562 vs 262 also.One thing unmentioned thus far: vibration. I was switching back n forth between a 350 and a 550 last weekend breaking in a rebuild on the 350. There is a noticeable difference in vibs from the saws. The 550 is much smoother. Of course this is not really a factor when making cookie vids but if I had to run one all day it'd be the 550. What a difference 15 years makes on a 50cc saw!
what do you have done to your 242? it runs good.
I think a little tweaking to the 242 and you will find some nice gains.
5100S is a very good saw, but it's not as fast as a 550xp. Same wood, chain & both stock, etc...Depends on what you're looking for, but I wasn't thinking about a 261.
lol no, I am one who doesnt care if one saw cut 1 tenth of a second faster then the other one, all I care about is how easy the saw is to work with.are cut times the only thing that counts with chainsaws ?
I also find it weird that most discussion is always cutting time, no one speak about balance, body shape, front handle angle, and so on.
