2017 MMWS GTG Box Saw Build Off Poll
Should we allow the builders to only use the parts that come with the kit?
  • Yes
    Votes: 31 56.4%
  • Yes, but also allow any 1122 series aftermarket top ends
    Votes: 20 36.4%
  • No, allow any hybrids as long as the top end is an aftermarket part
    Votes: 0 0.0%
  • No, allow any hybrids as long as the top end is an aftermarket part. And two piece heads.
    Votes: 4 7.3%
  • Total voters
    55
Lightning Performance
10:35 PM
East of Philly
Stock appearance AM jug no boost ports, welded exhaust etc.
Only possible swaps I can see are. Oem carb, coil, clips, wrist pin bearings.
Saw should idle 1-2min before making the cut.
Keep it simple, keep it fun.
If someone wants to go wild with the kit, enter it I the 6ci class...
Yea.
No machine work either.
OE Carb or AM is cool
coil should be AM
Clips and pin bearing should be OE
OE and Ceramic crank bearings should be out.
AM pistons and NO CABERS!
NO OE pistons and NO Meteors
7 pin only
Most of the kit should be run if your really looking to "test a box kit."
10:35 PM
i plan on no machine or port work just simple muffler mod if needed and oem carb if the aftermarket isnt worth a crap
Backtroller
9:35 PM
Land of Badgers
I don't really care what the rules are. I'm going to build my saw in a box as is, get the bugs worked out, then port it and make it as strong as I can.
This is all about the fun for me! And hopefully I can learn something while I'm at it!!![emoji41]
This is the spirit I'd like to follow if I could port a saw. Awesome idea Dan!
jmssaws
Banneded
9:35 PM
Agreed.
If we build the same saw with the same parts then you will find who built the best saw.
David Young
Safety First !!!!!!
10:35 PM
vt
I say if you want a prize make it so it's a raffle for those making an entry
You do a build thread and offer a saw then you get into the drawing for a mastermind t shirt. I say you can sand the base but can't cut the squish
9:35 PM
Agreed.
After being in a bunch of these build offs I can assure you it doesn't work that way either.
What we will find out is what saw cut that cut fastest on that one day.
Best saw is not really possible to nail down. Too many other variables.
jmssaws
Banneded
9:35 PM
There's no doubt.
If we're trying to get as many involved as possible then it needs to be build what's in the box.
Will the new guy who wants to enter do it if there's no chance he can win?
I'm in either way but if we can do whatever we want then I think it will keep some guys from doing it.
9:35 PM
There's no doubt.
What's in the box is a carb that don't work for chit, a chain adjuster that won't adjust, a wrist pin bearing that bound to fail, and a set of circlips that are soft as butter. You sure we should just use what's in the box?
10:35 PM
lol i do i want to show feedback on where they can improve
CR888
12:35 PM
Australia
KISS... keep it simple stupid. Think what your trying to achieve here...which may be 'what potential can be had out of one of these kit/box saws'. If that's the objective, make the rules accordingly. Once you let to many other options/variables in the mix....the objective changes. Don't stress Randy, many folks are into these kits or interested in them, imagine the knowledge that will be documented when all the builders really take a look at them closely. Great idea!
10:35 PM
i agree there
Adirondackstihl
10:35 PM
Upstate NY
That was my point....hence why I should make the rules :)
