084 vs 088. Which is better?
Stihl working Hard
Is it Friday yet
5:12 AM
Perth Australia
jb-chainsaws
10:12 PM
UK
084 vs 088, which is better? Neither? An 090, but one with AV, beats um both. And some would say them funny yeller saws beat um all
I may just happen to have a couple of them there 090's for sale in a few weeks :eusa_whistle:
Brewz
7:12 AM
Hunter Valley - Australia
What have others done for muffler mods on these?
On the 084, there are 2 holes and one has a little cover over it directing the outflow at the 2nd rearward exit.
I am thinking about grinding the little cover off and opening the exit hole up, and then braising an @Red97 deflector on the flywheel side for a 2nd port
Thoughts?
Brewz
7:12 AM
Here is another one.
I hate how restrictive the filter cover mount struts are over the intake.
Does anyone know why it has the flat section across the bottom?
I am thinking I might free up the inflow like I did on my 064
Brewz
7:12 AM
Inside the motor looks pristine through the plug hole and exhaust.
That have been running a HD filter with its rubber gasket on the rubber gasket on the saw and looks like it was sucking in a bit of stuff.
Will remove the rubber ring on the saw intake plate.
It blew good compression so should come up nice.
I might even keep the OEM piston and cylinder stock seing as they are in such good shape and get a cross top end to grind on.
Are they any good?
Deets066
AKA Deetsey
5:12 PM
I would port the oem top. Do some reading and talking to those who have ported one of these before and go for it
jb-chainsaws
10:12 PM
UK
I have a spare 084 top end that I'm half tempted to trade for a cross performance one, just because I'm curious how they run
4:12 PM
@jmssaws
@Mastermind
Do you boys have any advice?
I've done quite a few 084s. They don't need much. I add a little compression, and let the machine work take some of the exhaust duration away. Take note of the stock transfer height, and let that guide you.
VinceGU05
one day when i grow up...
5:12 PM
S.E Australia
And they go like stink let me tell you ![emoji6][emoji1360]
Brewz
7:12 AM
I am really excited about this one.
I am going to clean it up a bit over the weekend and check everything is ok, give it a muffler mod and run it stock on Monday to see how it goes.
Then it's getting torn down for a proper birthday
Brewz
7:12 AM
Gave it a rough cleanup this arvo and tried to start it
No spark
The coil is long and looks like the limited coil that I had on an 064.
Do they take the same coil as an 066?
The flywheel has dual key ways so I figure it is good for limited or unlimited
Iron.and.bark
Eats trees & drinks dinosaur juice
5:12 AM
Australia
You can use an 066 coil, but you need to make a bracket to hold it securely due to mounting points. Secondly I had to grind the coil to shape so it had clearance from the flywheel. Works well, especially considering the 084 coil is unobtainium.
Brewz
7:12 AM
Ahhh larger diameter flywheel.... yes.
Did you keep the top mounting point the same?
