066 Handle bar identification.
cease232
2:40 PM
Montana
jacob j.
Only the weird
11:40 AM
Coastal Oregon
If you have a 3/4 wrap handle, the easiest way is to lay it on your bench, forward facing down. The older style (3603) that is more straight across will lay
almost flush on your bench. The newer angled style (3611) will not sit flush or near flush at all.
cease232
2:40 PM
Montana
Thanks JJ. That’s exactly what I needed to know. I’ve got one of each. The 3611 works fine with a 9103 flag. I guess I’m stuck finding a 9105 for the 3603 then right?
jacob j.
Only the weird
11:40 AM
Coastal Oregon
It depends on which chassis you have - if you're building an 064, then you need 9105. If you're building an 066, then you need 9106.
cease232
2:40 PM
Montana
Was destined for an 066 but I wouldn’t mind putting it on my 064 either. Guess It’ll depend on what’s out there.
singinwoodwackr
12:40 PM
moon
Ok, ancient thread…
But…
Will a 9106 work on an 064 with wrap?
singinwoodwackr
12:40 PM
moon
Either a 9106 or a 9104 with a spacer.
The 9105 is the stock brake handle for the straight-across wrap on the 064.
Ok. I have no idea what 1122 wraps I have :p
I was going to send David a handle cuz I thought I had a bunch. Turns out, they are all 1128s 🙄
I need just one for my 064 build and the 9106 is all I could find :p
jmester
2:40 PM
VIRGINIA
I think this washer would work well to close the gap between brake handle and recoil.
3003 655 9200
Washer
worked well to use the 880 brake handle on an 084
