066/394 hybrid build
Scott0154
Feral member
9:37 AM
Central Valley Ca
I'd be an a-hole if ididn't upload this to share...here's a clip of it with the carb still not right. It's hammering some pretty hard knots too.
I can't wait to get a carb in better shape on it. I'm trying to make my mind up on whether I want to use the modded carb from my 064 pipe saw or just grab the one off my 880. I suppose I'll start with the easiest one to attach.
You can install sealed bearings on the throttle shaft to fix it
Chainsaw Jim
Con Artist LLC
9:37 AM
Springfield Oregon
Ok...this is more like it. I installed a stock wj69 carb and it runs much better. I replaced the intelli-carb plate with an older flat one with a vent hole so it won't lean out past where it is without some pop off adjustment. Now I just need to match a carb to the one I modified on my 064.
12:37 PM
Sounds good Jim. How does it feel when working it?
12:37 PM
Cool. I am sure you will find it. [emoji106]
Adirondackstihl
12:37 PM
Upstate NY
Awesome!
Sounds like a 394, so what is it about huskies and stihls that give them there distinct sound? It's obviously in the topend as demonstrated here...
I believe it's (not in this case because it's a dual transfer cylinder I believe) dual vs quad port for the most part.
In this case, it's probably port shape, tunnel entry and timing.
