066/394 hybrid build
Deets066
AKA Deetsey
2:16 PM
I was thinkin maybe one could drop the jug more without freeporting but still maintain a larger exhaust port?
It won't let you drop the jug more. The top of the step is still the same exhaust port floor.
I've never tried it, anyone ever done a before and after with just that?
Keith Gandy
Maxima K2 40:1 87 Pump Gas
1:16 PM
Provencal, Louisiana
Yes I understand that but it lets u make the port bigger without altering the existing floor height at the window?
Chainsaw Jim
Con Artist LLC
11:16 AM
Springfield Oregon
Theroy behind the "step"? please.
Sometimes you can't enlarge the exhaust enough without free porting below the piston. In this case I had plenty of room if I wanted to make the floor flat at that level but the piston doesn't go any lower and is still exposed. If I take the step away and then end up lowering the cylinder I will risk exposing under the piston.
It is a proven method. You're enlarging the outer exhaust to increase velocity of the escaping charge while keeping tolerances in check.
beaglebriar
The Peanut Gallery
2:16 PM
Warren Center, PA
I put a step in my 372 just because Randy was talking about it. It was around the same time I started the build. So I figured why not?
Deets066
AKA Deetsey
2:16 PM
Being more open wouldn't it reduce velocity?
Couldn't the same thing be achieved in opening the port at ex. Flange the same you have and just taper back to the port?
Chainsaw Jim
Con Artist LLC
11:16 AM
Springfield Oregon
I guess it doesn't really gain velocity, it's more like the escaping charge has more open area to escape so it doesn't lose velocity. If it's tighter there the escaping charge fights more to escape when it slams a shallower surface.
Deets066
AKA Deetsey
2:16 PM
Yeah that's the way I see it.
I've been tapering mine from the cylinder wall to the ex flange, getting bigger as I go
mdavlee
Hillbilly grinder
2:16 PM
TN
Ace Morgan was the first to grind it intentionally in chainsaw ports that I know of. This was in the late 80s early 90s if I remember what Glen and Jacob J said. Terry got a saw from the west coast that was done like that.
Chainsaw Jim
Con Artist LLC
11:16 AM
Springfield Oregon
Well.... sorry about the hold up. That WB carb isn't going to hold a tune for chit. The throttle shaft is very loose in the carb body and has a large enough gap to suck air. It'll hold a tune for a rev or two then it just goes all over the place. By the time it gets to the wood it's already way off.
I'm going to have to put the carb from my 880 on it to get a good run out of it.
Chainsaw Jim
Con Artist LLC
11:16 AM
Springfield Oregon
I'd be an a-hole if ididn't upload this to share...here's a clip of it with the carb still not right. It's hammering some pretty hard knots too.
I can't wait to get a carb in better shape on it. I'm trying to make my mind up on whether I want to use the modded carb from my 064 pipe saw or just grab the one off my 880. I suppose I'll start with the easiest one to attach.
