066/394 hybrid build
Chainsaw Jim
Con Artist LLC
12:16 PM
Springfield Oregon
I got into this thing and next thing I know it's after 3am. Lol
I decided on the 394/395 piston and put it on a little weight loss program. I was able to leave the skirt at full length by relieving a little area on the edges of the crankcase. 20161010_032842.jpg
Here's the cylinder with the holes offset and sized tight to the bolts in place for perfect alignment. 20161010_032945.jpg
Tomorrow I'll relieve a little bit of area on the case so it'll sit down in place.
I plan on using a 3mm spacer gasket to start off with to see how it runs, then go from there. I'd hate to miss something by immediately lowering the intake.
paragonbuilder
3:16 PM
Norwich, CT
I decided on the 394/395 piston and put it on a little weight loss program. I was able to leave the skirt at full length by relieving a little area on the edges of the crankcase. View attachment 36826
Here's the cylinder with the holes offset and sized tight to the bolts in place for perfect alignment. View attachment 36825
I like how you experiment Jim! This is great!!
Chainsaw Jim
Con Artist LLC
12:16 PM
Springfield Oregon
There are a couple reasons why I'm not using a 395 cylinder. For one I'm only using what I have on hand which makes the decision easy for me. Then there's the intake difference. Although the 395 is set up for a rubber boot from the factory, I think the 394 intake can be made to be larger than on the 395.
Deets066
AKA Deetsey
3:16 PM
Will the 66 case handle a huge intake though? Or will you just end up with a lot of spit back?
Chainsaw Jim
Con Artist LLC
12:16 PM
Springfield Oregon
Yeah that's what it will likely be though I would rather deal with all the beginning stage work with something a little easier to handle. I'm also kinda hoping to have a good sleeper that piped saws won't see coming so I might mod an 064 muffler to fit.
Chainsaw Jim
Con Artist LLC
12:16 PM
Springfield Oregon
Another late night in the books.
It's ready to bolt down and start putting together. There's a few more cylinder fin edges to clip so the 064 top cover fits and I still need to put a few minutes into shaping the intake. 20161011_032653.jpg 20161011_032753.jpg 20161011_032818.jpg
Chainsaw Jim
Con Artist LLC
12:16 PM
Springfield Oregon
Sorry to be taking so long on this thing. I've been dikking around the shop looking for the right material for a spacer and figured I'd make use of a bad cylinder by chopping off the base and using it. Only thing is I blew it on the first cut by cutting it way too thick and now I have to cut it again without the rest of the jug to hang on to.20161013_161128.jpg
