SOLD 066/056 Mag II hybrid diy kit
Trader history (5)
Woodslasher
Teh debil
10:06 AM
Commiefornia
Awhile back I decided I was gonna build an 066/056 Mag II hybrid so I assembled all the parts, got the cylinder to bolt down, and that was as far as I got. I know that either the band needs to be cut or a spacer fabbed up, I just no longer have the time or motivation. Or, sell the 056 top end and bolt on an 066 cylinder and just run that. In any case, I'm selling the whole parts lot as a unit.
Here's a fairly comprehensive list of what's included:
OEM parts:
Top cover
2 carb boxes and a filter base
Loaded crankcase
056 cylinder
Carb
Coil
Misc smalls are all oem as I recall
A/M parts:
Unknown recoil and fuel tank
Madsens 3/4 wrap, I think it's a bit tweaked but fixable
Hyway wide clutch cover
Hyway DP muffler with the outlets opened up a bit
2 Hyway big bore pistons
timg
1:06 PM
Keystone State West
Looks like a good challenge for your machining capabilities Greg. I think you may need to devise a decomp port somehow too. Daniel, No embedding of material on that cylinder wall? Maybe just the pic but it looks a little rough.
farminkarman
I like the red & black ones
12:06 PM
Neenah Wisconsin
It is intriguing to be honest
ManiacalMark
1:06 PM
PA
You really just change the angle of the exhaust port and it works, but then the cylinder is only good for a 64/66.
Woodslasher
Teh debil
10:06 AM
Commiefornia
Doesn't seem to be anything embedded, just marks.
Woodslasher
Teh debil
10:06 AM
Commiefornia
Bump, almost 6 months of sitting under my bench without being touched means it's back on the market.
Bill G
12:06 PM
When someone buys this I might have a few parts here to help them along........no good ignitions though
Bill G
12:06 PM
Whenever I list a used saw saw on FB or CL I get folks wanting to know if I have any "project" saws. Well folks here is a true project that someone needs to undertake. The price is right, the challenge is right, the end goal is right so someone needs to do it. I would buy it myself but the simple fact is I know it would just sit in a tote here and get forgotten. I have so many vintage saws to go through I would not get to it.
Woodslasher
Teh debil
10:06 AM
Commiefornia
Yep, I'm about done working on saws these days. I've got a CP125 I've had for 3 years that just needs the clutch lapped to the crank and a 1-81 I need to tune up I still haven't touched in a year or so. Those may yet go on the block, but at the moment I'm just thinning out the projects I doubt I'll ever get around to. The end result will be pretty neat, but I just don't have the time or motivation to get it done. My truck project is finally building up steam after 4 years and I know that'll be at least a year or two before I get it done.
Maintenance Chief
1:06 PM
South Carolina
So are you just focusing on the truck?
Maintenance Chief
1:06 PM
South Carolina
At the moment, yes. I'd like the truck to be the only real project occupying my time and under my bench to be free of projects in the meantime. Plus, I only run a saw 3 times a year these days anyhow.
It's a 70s Ford F250 right?
