064 need suggestions
Status
Not open for further replies.
jmssaws
Banneded
5:41 PM
I took my lightened piston out of my 64 hybrid. They may be ok but IMO they have no place in a worksaw
Was this saw a work saw?
I think it was built to be as fast as possible.
Spin one to fast and things break.
I've done it once and about done it again trying to run one that fast.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
5:41 PM
Provencal, Louisiana
All my saws are firewood saws . I would like it to be fast as possible but reliable at the same time. Like I said earlier they may be fine lightened but I went 96g to 80g and that just made me feel uncomfortable . I put a oem back in it and shaved the crown alil
jmssaws
Banneded
5:41 PM
Before the saw grenaded I told Edwad to send it to me because something was wrong,he didn't
He sent it to Brad and when Brad got it
It was 170lb of compression with 040 from the chamber and that's not possible unless it is hurt. It was almost 200lb when it left me.
When Brad got it it was tuned to 15k and no 4stroke period.
Instead of asking me what compression was or anything he just ran it and it broke at 14.3k piss revving.
I've talked to Brad and he said nothing to do with porting caused it. It was over speed that cracked the piston and he finished it off.
Does a 066 turning 15k sound like a work saw?
The fact it was tuned past 4 stroke is enough to end warranty but I still said to Edwad,send me the saw and I'll fix it free of charge but he won't so what else can I do?
He needs to send me the saw or shut up and quit crying.
Lightening the piston certainly weakens it
And I don't use them in a work saw but I was told to make it as fast as possible.
There's 50 or more saws I've built with the same piston and I've never had one fail nut nobody else will tune one that fast.
I tried once to run my saw at 15k
Exploded the piston and I tried once more
Here's the stock oem piston from it after less than a tank. I got lucky and seen it
jmssaws
Banneded
5:41 PM
Who can look at the piston from this saw and say it had to much removed?
It's in tiny peices.
Nothing fast lives forever and when you have one built you need to accept that.
Still I'll fix it for free if he will send it to me. I'm not sending Brad parts or money to fix it period.
I'll not say anything else.
jmssaws
Banneded
5:41 PM
I found out about this from watching the video on the forum.
Is that how you contact the builder?
What can you gain by crying on here about my shotty work?
And after I've told you 10 times I'll fix it You still get on here crying.
Man up because you're acting like your wrists are a little limp.
Edwad
5:41 PM
Indiana
Yes you did offer to put it together if I sent it back to you if I furnished new P/C, gaskets and bearings. But Your work absolutely sucks! Bolt holes that are stripped and supposedly it had OEM P/C which it didn't. Really to many issues to write about. I feel sorry for anyone that has to deal with you. That's all I have to say right now.
Edwad
5:41 PM
Indiana
Thankfully you have a good following. I can tell you I'd never use you.
Edwad
5:41 PM
Indiana
This is done And over with. Let's move on. I have had enough of this.
jmssaws
Banneded
5:41 PM
I told you last night to send it to me and I'll fix it for free.
There was no bolt holes stripped or anything shotty.
You have no idea what your talking about.
It absolutely had a oem cylinder and a meteor piston. Who told you it had a oem piston?
Remember I didn't build the saw for you so whatever info you got wasn't from me.
You didn't take it apart,you didn't even start it.
You absolutely no nothing about what's going on.
I asked you 3 weeks ago to send me the saw,long before Brad blew it up .
Edwad
5:41 PM
Indiana
You twist everything in your favor. Some people will believe you. I understand you struggle for success. I am glad folks can get another view of you. The quality of your work absolutely sucksssss. That's something I got to experience. I only hope others have better luck.
jmssaws
Banneded
5:41 PM
I'll fix the 1000$ worth of damage that's not my fault but instead you want me to send you a few hundred dollars and you will take care of the rest.
Does that make sense to anybody?
There's something else going on or why wouldn't he send it back.
I talked to Brad for 2 days about it and never once hears that it was a am cylinder or there was a cylinder bolt stripped besides the way it looks I don't know how any bolt holes would be good.
Nothing you say is correct.
You'll spend that much money just so you don't have to send it to me?
Something ain't right and all you are doing is hurting yourself.
Edwad
5:41 PM
Indiana
Honestly Imay want to sell this saw someday. I think folks wouldn't want it if they knew you ported it. Better to deal with someone more trustworthy.
6:41 PM
i am staying out of this but i will give my opinion if i tune a saw and something breaks it is my fault i have a couple saws al did and one from a few others in no way would i expect any of them to repair or replace something i broke
Status
