Jchin
- 2:52 AM
- Apr 8, 2016
- Warwick, RI
Nice to see you pop in Jack.
Hi Mike, Thanks for having me here. I like it here on OPE, good people........
Talking to you this morning has put a smile on my face all day.
The AM cylinder will be a great way for you to be able to run your 064 again.
It makes better power than a oem and has a decomp hole, I look forward to getting it fixed up for you.
Thanks for the flywheel and the smile
Glad you come over and visit. How's the smurf family treating you?
The throttle response and feel of the am make it seem much faster.Mahle averaged the fastest. KS was harder to time consistent sitting on the log. AM made the fastest cut by .1 over the mahle but the 2nd cut was slower to bring it into 2nd. Less than .1 average. All were very close like that.
Mahle 8.25
KS 8.95
AM 8.36
Just looking at the video timer, that's about what I came up with too.Mahle averaged the fastest. KS was harder to time consistent sitting on the log. AM made the fastest cut by .1 over the mahle but the 2nd cut was slower to bring it into 2nd. Less than .1 average. All were very close like that.
Mahle 8.25
KS 8.95
AM 8.36
I've noticed that exhaust height seems to mean very little. If the am cylinder is stronger with a 24" most likely it will be with any bar.
The best runner with a long bar I've ran had the exhaust at 98.
The lower exhaust on the oem cylinders are hurting them. Low exhaust and a high intake doesn't mean it will run a longer bar better.
On a 066 I think 98 120-123 80 is ideal for how I do them.
064 i like 100 120-123 78-80
To bad the 066/660 cylinders couldn't be like a 064 cylinder.I like the 064 because you can get the intake sub 160 duration 80 opening and still machine the squish to get the compression and exhaust timing you want.
I like low intake duration for high crankcase compression with really large transfers.
