064 cylinder comparison
Brewz
8:56 PM
Hunter Valley - Australia
I measured the other jug with the damaged transfer.
No gasket:
103/124 to 126/73
both of the KS cylinders had progressive uppers with 2 deg between intake to exhaust side
jmssaws
Banneded
5:56 AM
I'm not seeing that Jason.
The transfers really seem to be the deal breaker with AM jugs if you ask me. If you really study the tunnels, you'll see why. I don't think where the upper in rotational direction to the lower is the only factor at play in charge direction.
I have no doubt that the transfers are the deal breaker.
I hope to run them today,gotta build a saw to run them on first.
Brewz
8:56 PM
At this stage, I plan to remove the muffler baffle and open up the side outlet.
It is already running a well opened up dual port front.
Will rebuild the BING carb i have and fit that up. Im not to keen on the walbro 10A on it.
Do the 064's respond to a timing advance?
jmssaws
Banneded
5:56 AM
I bloody thought so.
I couldn't lean it right out.
Well I am not completely insane then.
You cant say you have not seen one now!
I've seen one just not in person.
Brewz
8:56 PM
what is seen cannot be unseen
They exist.
limited = yuck
I need a flywheel for an unlimited coil for this one now
jmssaws
Banneded
5:56 AM
Is the flywheel dual key?
Doesn't take much for one to run good,it needs a little compression and a little more intake and a little less exhaust.
I wouldn't cut much off the base,030 or so
Brewz
8:56 PM
I have 2 x 064's here
One I was saving for the 066/288 jug but I may put it together and run it as an 064 for a while.
It has a dual keyway flywheel, unlimited coil and BING carb.
I plan a V stack and VERY open muffler
what would be optimal timing to aim for?
I should be able to make a mandrel to cut a touch from the squish and sand the base.
A bit more off the base so I can make a thin gasket for it.
.020 from squish and .030 from base should work
What timing should I am for?
I wont touch the transfers.
100/124/75?
jmssaws
Banneded
5:56 AM
Do I set all three cylinders at 020 squish or leave them alone?
6:56 AM
Are they within a couple thousandths? .020" would be fair if some of them are a lot different
jmssaws
Banneded
5:56 AM
I have a stock oem 064 muffler should I use it or a modded one?
Ignition advance?
