Deets066
AKA Deetsey
- 11:22 AM
- Dec 28, 2015
- Illinois
What is the notch in the bottom of the cylinder below the intake?The ks intake is poorly shaped
It's so the 064 gremlins could get out before someone threw a 66 jug on 'erWhat is the notch in the bottom of the cylinder below the intake?
I'm gonna say the last mahle will be the strongest.Is by the numbers and chamber over the others. The last mahle will be real close with the higher transfers over the other one.
Ugly don't make it slow though. That one and the last mahle will be about even I'm guessing. Rough texture isn't preferred past the intake port since the fuel is turning to vapor there but they usually run good any way.This ks is the worst one I've seen for finish,port shape is bad and ruff as a cob.
Ks is my favorite cylinder because of how nice they are but this one is terrible.
I don't think it will run bad it's just the worst oem cylinder of any kind I've ever seen. The intake varies several degrees from 0ne side to the other.Ugly don't make it slow though. That one and the last mahle will be about even I'm guessing. Rough texture isn't preferred past the intake port since the fuel is turning to vapor there but they usually run good any way.
