spin 701
New OPE Member
- 10:44 AM
- Nov 7, 2020
- pennsylvania
I have a 026 stihl which has the screw caps for oil and gas,it was made in virginia beach,its kinda confusing,because it was made in virginia beach,and not in germany,one would assume its a newer saw,but,on the other hand,it DOES have the screw oil and gas caps,,,,can anyone give me some guidance? now for my main problem,this saw cranks like a bull,its so hard to crank,especially when cold,i was told i could add a compression release on it,that some of them had a plug on the top of the cylinder which can be removed to accept a compression release,when i removed the covers,i found a black rubber nodule,directly across from the stud which fastens the top shroud on,i did not try to remove the rubber piece,to see what is underneath it,is it possible that that is where i can install a compression release,id really appreciate the input,coz,this thing cranks so much harder than my 440magnum,,,,,,thanks in advance
