2nd problem I found is this flywheel hitting coil in less than 10min run time I sanded cleaned flywheel when I just put the good coil in it and it didn't have them rub marks then.
And don't mind the rust marks on the flywheel from the coil in the pic saw has been out in the rain I kicked it to the side of my wood heap after I dropped it in the last vid a few weeks ago only picked it up off the ground today lol.
I'm going to have to pull the saw apart and swap the crank/bearings with one out of a parts saw I have with less than a 1hr run time on it.
This POS won't beat me I will get it to run as it should at the minimum for a tank of fuel! Lol
