RI Chevy
1:52 AM
earth
I hope all turns out well for you Nick!
7:52 AM
U found this funny!
Hint: pay attention to the bar.
lehman live edge slab
Live Action
12:52 AM
Mn
Anyone use the nova chip on a stihl 031? I used one on a 032 worked great but now I put one on a points style 031 and it runs well but seems down on power. Acceleration is kinda lazy also, saw has 150 psi and I’m wondering if the module retarded the ignition some causing the lower power. I’m thinking of trimming key some and give a little advance to see if it helps. I’ve also read some people were using electronic flywheels but was also told to use only the points style. Not a large fan of the nova chips seem to be pretty high failure rate but it’s the main option at the moment. I think the now unavailable atom chips were more specific to use and better. Friend of mine that’s an electrical engineer is making some atom style chips for me. Few slightly different versions to find the best one for different saw applications. After
It’s all sorted out and we know they’re reliable I’m sure we will have some to sell so people can keep the old saws going.
Live Action
12:52 AM
Mn
Sorry the more I look this has been brought up before and I need to advance the ignition the way it sounds. So I’m wondering if I should try the electronic flywheel and see or if it will be too much advance. I’ll look at them both when I get home, and after it’s all sorted out maybe my friend can alter the timing in the electronic chip he’s making. Taylor one to the 031 points and one to the 031 electronic so it will be a simple hookup and mount it deal.
Live Action
12:52 AM
Mn
Well looked at both flywheels and if they are indexed using the keyway the electronic one’s magnets are exactly one cooling fin off to the advanced side. So while not the most scientific way to determine it being the flywheel has 24 fins and if you divide 360 by 24 each fin represents 15 degrees. So since the electronic flywheels magnets are one fin off it should fire 15 degrees earlier than the points flywheel. I tried the electronic flywheel on saw and it runs like a champ. Now the saw has the electronic flywheel, points coil and a nova 2 chip. Runs perfect and has the power and acceleration it should.
Homemade
1:52 AM
Wisconsin
Any ideas on removing the flywheel on an 090G without using the Stihl flywheel removal tool? I managed to get a 3jaw puller on it and gave her a few whacks with a hammer to no avail. It is soaking in penetrating oil. I don’t want to use heat cause of the ignition component behind it.
Any suggestions
Live Action
12:52 AM
Mn
I wouldn’t use a three jaw puller you can wreck the flywheel. Need to pull it from the center I bought the double sided aftermarket puller to remove them off eBay for like 15$. To me it isn’t worth wrecking stuff without it
mdavlee
Hillbilly grinder
1:52 AM
TN
Any suggestions
Little heat from a heat gun or hair dryer and penetrating oil should do it. Don’t use a propane torch on it.
Homemade
1:52 AM
Wisconsin
I didn’t realize they were so cheep. Never thought to look into the aftermarket for one.
Any other tools like this you guys recommend?
Homemade
1:52 AM
Wisconsin
$5.59 shipped to my door. How can they even buy the raw materials much less get it to my house for that price.
PogoInTheWoods
1:52 AM
Ohio
I'd go with the Bosch/Puch flywheel puller version from Treatland.
https://www.treatland.tv/puch-bosch-flywheel-puller-p/puch-bosch-flywheel-puller.htm
Had mine for years and pulled dozens of flywheels with it. Very high quality and fast shipping. Wouldn't trust a 5 buck cheapie puller as far as I could throw it.
As for other handy specialty tools, the Husky case splitter comes to mind. Hafta pry the forks apart to straddle larger Stihl cranks, but it works great all the way around for most saws.
https://www.ebay.com/p/Chainsaw-Case-Crankcase-Splitter-Tool-for-STIHL-Husqvarna-Others/1268638138
There's even a guy in Indiana making these available as kits for $35 if you can weld.
Frank bierce
10:52 PM
Oregon
Be careful with the aftermarket ones on the 090’s.....not a whole lot of threads to engage. I had mine strip out on the 090. Still works perfectly on everything else though.
1:52 AM
Before they were so cheap I used metric hydraulic tube banjo fittings which I think were 22 MM for smaller Stihl saws .I think I used 12 MM bolts or 1/2" fine thread which were a perfect fit for the ID of the fitting to make the pullers which worked well .Keep in mind I retired from an automotive engine plant and had access to tons of goodies I could adapt limited only to the imagination .
Homemade
1:52 AM
Wisconsin
The flywheel or the tool striped out? I’ll be careful and not use the impact. I can be patient. Might even try the heat gun.
