The mighty stihl 064 and early 066
ferris
3:52 PM
Germany
Do you mean the high output parts from the 066 won’t fit in the oil pump 1122 640 3204?
Or what do u mean?
jacob j.
Lord of Cargo Pants
6:52 AM
Coastal Oregon
Picture is not possible at the moment. Saw is running nearly daily. But I have the „new“ pump after the change. Look at the ipl picture I made.
Would that make the new pump which shared parts with the 066?
An easy way to tell the two pumps apart -
The early oil pump used an adjustment screw with a large round head and a single large straight slot
The later oil pump uses an adjustment screw that has a smaller, stepped head, is flat on one side, and uses a small straight slot.
9:52 AM
Plus I think the early 064 pump has a multi turn control bolt
qurotro
Cookie Cutter
8:52 AM
Ar
My early 064 oil pump has a multi turn adjust screw. may be 4 or 5 turn from max to min.
Evansaw
4:52 PM
Greece
I wanted to have the pair all restored and beautiful but the Post Office ruined my Xmas gift
One damaged, by post office has a bandage to make up with epoxy
It's the standard handle saw dynoed at 10.58hp
The 3/4 wrap is another restoration
I have a feeling that power wise will be NORTHERN than Santa Claus houseIMG_9794.jpeg
ferris
3:52 PM
Germany
@srcarr52 which carb do u use?
I have a wj10a carb on my ported one. Is there a better carb for more power?
srcarr52
9:52 AM
Iowa City
I haven't really noticed a difference between carbs. I usually modify them and open them up so the differences are negligible.
