Sugihara vs. Tsumura pricewise
CR888
12:22 PM
Lots of husky saws have a grease hole
If you get used to this clever husky design, be careful as other brands threaded crank stubs 'appear' to have a hole for greasing but its just a closed tapered hole. But Husky was clever doing that especially as you need to remove the outboard clutch to get to the drum bearing. I don't know why others don't make it easy & follow suit, the cranks don't seem to fail as a result of the removed metal.
SOS Ridgerider
Muffler Modded Member
10:22 PM
Central CT
242xpg
... remember this is also is from sweden!!
LMFAO!!! I remember that song. I must have been 7-8 years old. Wasn’t that on the Eurovision Song Contest? That contest has produced some memorable, not necessarily good, songs.
10:22 PM
It belongs in the whiskey tango foxtrot thread
deye223
AIR FUEL SPARK VROOOOOM
12:22 PM
did someone say whisky ..........
after a few of these :godsdrink0nw:
I think I can dance the tango and the foxtrot ........... but in reality I look like a fresh caught
salmon on a hot plate ........... :qpasaneng2: :facepalm:
anyway I would rather drink cans and listen to banjos :guitar: :borra2::beer-toast1:
Master Bud II
7:22 PM
Northern Ca.
Do
Or maybe the engineers at the companies that still use five or six rivets said, "You know, four rivets is plenty strong and we could increase our profit margin by switching to four" but the marketing guys said, "All the other big mfgrs are still using five or six rivets and people won't buy bars with four rivets, even though they are plenty strong enough" ... so five or six rivets remained the norm.
Kind of like shotgun shells. The "high brass" or "low brass" is a non-issue anymore, except for purposes of quickly visually distinguishing heavier-load shells from lighter-load shells – in fact, they could make them with NO brass or metal at all on the head – but they would likely lose market share if they did that, as well as spawn long Internet debates about "how much brass is needed" when the correct answer is "None."
Dose anyone Remember "Active" Shotgun shells, I Still have one in My Shell collection "NO BRASS " Just a Thin perforated steel disc in the head of the shell so the Extractor doesn't pull through and Extra Grip for the primer so it dosen't set back during ignition ( Late 80's ). Now a New type is being tested by the Military in Rifle calibers,,, .223, 308, 300 Norma Mag, & .50 Bmg... soldiers can carry 45% More ammo, for the same weight + The Barrel stays cooler during a firefight....
Sorry for the Devert... Worked in the Firearms industry for 9 years, prior to becoming LE...
10:22 PM
You mean the old shells made of card board and just the brass plate?
Master Bud II
7:22 PM
Northern Ca.
ALL Plastic, and where the Brass would Be it's bigger in diameter, and extends about 3/8" , Midway between a Low brass, and High brass case head... and each Gage was a different color, as is industry standard...
Bud
10:22 PM
Hmmm. Never seen one like that.
jakethesnake
I Am The Snake
10:22 PM
Here & Now
AD890A86-C397-4038-AAC1-8DB27C3E36E5.jpeg 4771BBBF-8E8B-463A-93E5-D61729DE020A.jpeg
Do
I remember....
10:22 PM
That was only in the beginning. They don't do it anymore.
dirter
10:22 PM
Logan, Ohio
Does anyone know where I could get a 16" TsuMura lightweight in Stihl mount .325 .063? Looks like the part number is 206sk2. Id settle for a regular weight or even a 3/8" that I can change the tip on. I already have a spare tip.
