I'd guess the 'old stock' tip is not the same as your new one next to it. Are they both 3/8 pitch?? My guess is the old one is .325 or .404.View attachment 151162 Pic of current tsumura tip and old stock tip
Nose sprocket bearings have completely different load requirements to clutch drum bearings FWIW. Think how the system works, 'when' does the clutch drum bearing function.
Correct. At idle, basically.when the chain aint moving ...
plus if you keep greasing it it all ends up on the clutch shoes
