Almost everything in a house is run off 120v here. Except for large appliances, shop tools, heating & AC, etc., which is 240v.So what do you guys run on 120v?
Ours is 240v for everything.
Cheers,Chris.
Starting my electrical rough in.... keep in mind, I’m not an electrician.
I like to run all the wires close to each other, to keep things neat. I pull one circuit at a time and label them as I go. I’m going to leave them dangling for now, and will pull them into the panel later.
I just write on them with a sharpie, pull them into the panel one at a time, and label the breakers as I go... but wiring up machinery is a little more complicated than wiring a house! I have a label maker somewhere, too.Nice! We have used a label maker at work we have to keep track of control wires.
Finished wiring my panel today. I’m really not an electrician, so I’m hoping I did it right...
View attachment 186153 View attachment 186154 View attachment 186155 View attachment 186157 View attachment 186158
I’m getting a headache just looking at that. Props to you man.Finished wiring my panel today. I’m really not an electrician, so I’m hoping I did it right...
That breaker isn’t wired up yet. I’m still deciding what size breaker and wire I will need... which depends what size mini split system I decide to run.Looks real good. The 2 pole 20 breaker on the bottom right looks like it's missing one leg. ??? Photo could be a little deceiving too.
Square D makes a nice panel. The AFCI (Arc fault) breakers can be tricky at times. And the AFCI/GFCI's too.
You did good.
This has been a great thread. Everything looks awesome.
Been a while since I’ve posted here...
I did run all my water supply lines. I use expansion PEX just because of how simple it is to install. And I started installing my waste lines/vents. A friend of mine who is a plumber helped me to make sure I did everything right.
And I also started on the roof, but I have a long way to go... I’ve done about 350 sq ft and have another 1800 to go. The rest of the shingles will be delivered on Friday and the plan is to install next Saturday.
