- 2:49 AM
- Dec 3, 2015
- Banner Springs Tennessee
I've bought several things from this company. So far, I've been very happy with everything.
My only concern with the 780w version is what drive cables are compatible with it as you'll break one eventually. I know the cables for the S-R cables are available in many places.
I directly asked about cables, and if a easily available standard off the shelf item, and if they had them as well. Question was asked this morning.
They are saying that SR pieces work with this product.
After all you've said about them, it's no wonder. LolMy alumihog burrs never load up, except on newer Husqvarna jugs. Weird huh?
Seriously though, I've been dipping my bits in tap magic for faster cleaner cuts without sticking to the burr bits no matter if regular, double or hog cut.
I wonder if dipping my burr in WD-40 would be a good idea?They smear even with nice carbide when machining the bases too. I found that a good spray of WD-40 will get you a much better surface finish.
transmission fluid might work well too. For now, I have some tap magic in a jar and dip the burr lift it out and give it a spin to rid the excess off in the jar and go to work. Just the right amount sticks and stays to the burr, so it's kinda goof proof. Gamechanger for sure.I wonder if dipping my burr in WD-40 would be a good idea?
Gotta have the proper mix. Blackberry Poulan Pro bar oil 50/50 with Walmart spray lubeI wonder if dipping my burr in WD-40 would be a good idea?
Is this a trademarked concoction?Gotta have the proper mix. Blackberry Poulan Pro bar oil 50/50 with Walmart spray lube
It’s better than renting pigsIs this a trademarked concoction?
Yeah? Dino or full synthetic?So what oil is best and at what ratio do y'all use when dipping your burr??
DamifinoSo what oil is best and at what ratio do y'all use when dipping your burr??
