- 12:32 AM
- Dec 4, 2015
- In a meeting
Tuned pipe is the most efficient and makes the most power because it puts hot atomized fuel back in the chamber.Sounds like Keven has done the proper muffler testing (with each one producing more power in the cut) so that my concern IS NOT VALID HERE.
And DEETS and Keven are both right that a 2 cycle is not real efficient, and it will always release some unburnt fuel, and the IN GENERAL the more power you produce the more unburnt fuel will be released.
That said, the premise that excessive unburnt fuel will always produce more power is FALSE, and I believe TM has commented on it in the past.
A 2 cycle engine is not just a constant flow, it is a series of pulses (all engines are), and when your components are in sync it will run better. There are situations when some additional back pressure will produce more power.
There are times when excess unburnt fuel being drawn into the muffler will cost you power. Fuel remaining in the combustion chamber will produce more power than unburnt fuel in the muffler.
Even a tuned pipe has a very large expansion chamber and a small outlet. Think about why that is. To listen to Kevin and DEETS, you would think no muffler at all would out perform a tuned pipe, but that is not the case.
Backpressure at exactly the right time right before the exhaust closes... from 26” awayNow how could it do that, except with back pressure?????? Hymmmmm.
Yes, and "untuned" back pressure will not work as well, but it may provide some benefit.
I bet that sounds awesome.....Mike, I think you are on to something here !!
I’m going to have THE most efficient 394/395 on the planet !!!
Should be nuts with all the torque too, unless if’n you think the openings are too big ????
View attachment 237187 View attachment 237188
Tuned pipes work on resonance waves that both push and pull exhaust gasses even drawing unburnt charge into the pipe then stuffing it back into the cylinder just at the right moment. Its an acoustic sound wave resonance that is reflected pushing back charge into the cylinder. This is why idiots who think they can turn their can style saw muffler into a tuned exhaust are bonkers because they don't grasp the basic physics of the situation. Tuned pipes are big fat and long because they have to be, you can't change the speed of a resonant wave so it needs time to exit the exhaust and bounce back off the diffuser cone and return back through the header into the cylinder at the right time for it to be effective. Yes some back pressure is needed but the magic of the expansion chamber exhaust lies in its use of sonic resonance. But anyways...carry on.Now how could it do that, except with back pressure?????? Hymmmmm.
Twas installed on a brand new, 100% stock 395 that was ran at the CT GTG, 7 tanks of fuel !FYI, my recommended 2 - 1/4" holes are for relatively stock 440 and 460/461 saws. I open things up more on larger saws, and predict a ported 395 will need much larger openings.
but on this matter we will just have to disagree.
Let's move on.
Presuming you have the original factory outlet in addition to your two "horns", you now have the perfect test bed for your saw!
Don't forget to re-tune it, and do some timed cuts and see if your popping goes away.
Then, gradually increase the size of the holes and re-tune and do more timed cuts, and see if the times keep increasing and when the popping returns (presuming it goes away in the first place).
Will be interesting to see the results.
That said, this also demonstrates that the unrestricted flow of exhaust does not always provide the most power, and anyone who has seen a good running piped saw knows that.
While waves bouncing off the inside cover of a muffler will never result in the push back that a pipe can generate, they may stall the escape of some unburnt fuel enough to provide some additional power.
The venting of the muffler will always effect the RPM at which this is most effective. It is just far less effective and much cruder than a tuned pipe.
As I previously stated, it is a series of pulses, not a continuous flow. Timing is everything, and when you open up a muffler it may got through cycles of better and worse (the power change may not be linear).
