dmb2613
- 11:28 AM
- May 13, 2018
- Randolph Virginia
I paid with pay pal I am sure he has my pay pal address
My thoughts! You know you have a problem with a past sale ! Make it right for all on the forum to see .I admit I should have reimbursed for the crank immediately but I put
Piston and cylinder damaged when you received the saw in non running condition?I can take pics, I did contact him, the bearing on the crankpin is bad the piston has a chunk out of it as does the cylinder.
Lone Wolf is sending me a coil for it / nc. He knows what I paid for the crank.
Point noted...lolHey even if it was a POS at least he sent it. Crackhead Jim can’t even manage to do that.
Boost ported piston?View attachment 207643 View attachment 207644
I only asked for money for the crank, I had it in the back of my mind that the piston would be toast as well as the cylinder.
Live and learn , this whole deal took forever would take him days to respond. and then no reply for weeks
He said he bought this piston off ebay. who would buy this?
That *s-word not funny Deets.Boost ported piston?
Lol
He got *frenched. You'd be pissed to.
You can clearly see someone wasted their time sanding on that pos. It might be good for a set up case just for checking things or a cutting tool. Piston...not so much. Will it run, yes. Does he deserve a kick in the sack for sending it to you?
Yes and then some.
“220, 222...whatever it takes!” LmaoDiscounted for Ope members
https://asheville.craigslist.org/tls/d/fairview-oem-remanufactured-stihl-ms/7017316274.html
What is wood tested?Discounted for Ope members
...beat off to it I suppose or stuck his pecker in it one!What is wood tested?
That's what I wanted to see: no serial number, and AM muffler. I wonder if the number is under the paint?Discounted for Ope members
