- 5:19 AM
- Dec 3, 2015
- Banner Springs Tennessee
That sucks Randy. Maybe some epoxy might hold it in place. Going to always be a weak spot though without being welded.
That's a bish, but chit happens.Neither of those will be good enough.
I'll replace that case half.
So what do you do with all your broken case halves?I've lost count of how many of these I've seen broken off.
Bottom right...needs a rebuild as it ate a locating pin.
Coil should be in tomorrow. Probably be Thursday afternoon before its together. I am ready for it to go back together and leave!Running yet?
What am I missing? Why go through all that time and money to fix or replace case half for that?
Ten fo. Just making sure that there weren't bigger issues when that gets damaged. One of my saws has that cap protector cracked at the base and bent slightly toward the rear.
DON'T LOOK LIKE NO CHICKEN DINNERWinner winner! This came in today...
Hmmm. Well we will see shortly how it does out of the box. If it needs an MDG1 it will get one attached. Ill let you all know how it does...Jimmy , that coil will have to be set up (I believe) with the MDG1 after it’s installed. Didn’t think of it until now.
