- 6:40 AM
- Jan 28, 2016
- Dike, Iowa
Yes I do believe so. This one was painting my fingers black when I started cleaning it. When it sees fuel again it'll start turning gummy.Are you needing a boot Jim?
Thank you very much Lee!I gots a spare boot, Size 12 ready ta kick ya up yo back side.
Send me yo addy and it's yours. It is used but still very good.
Sounds really good. How much port work did you do to it?I figured what the hell and popped it together, with the not so good boot, just to run it. I lubed the hell out of it and got it on there without the lip ripping open.
View attachment 110013 View attachment 110014
It seems to have pretty good throttle response. Inside the garage makes it sound like it's revving way way higher than it really is.
That’s an awesome sound right thereI figured what the hell and popped it together, with the not so good boot, just to run it. I lubed the hell out of it and got it on there without the lip ripping open.
Yes for sure, I got busy and forgot to pm you... my apologies.Don't sound bad at all. Running it without the clutch will make it real snappy
and feel like it has monsterous compression.
Do you still need the boot?
Thank you, I only worked on the exhaust. The new reed valve is what really makes it run good. As Lee mentioned about the clutch... it makes a big difference when the bar and chain is on there.Sounds really good. How much port work did you do to it?
Looking forward to seeing some test cuts. Great build thread btw.Thank you, I only worked on the exhaust. The new reed valve is what really makes it run good. As Lee mentioned about the clutch... it makes a big difference when the bar and chain is on there.
Thank you, I'm anxious as can be.Looking forward to seeing some test cuts. Great build thread btw.
Thank you kindly sir!She's running pretty good. Now slap a 60 incher on her and see what It will do.
I have a SP125 I restored and I run a 60 incher with 3/8-8 and it pulls it nicely.
Boot went out today. USPS said Monday arrival.
It looks really good. Are you happy with it, or are you going back in it?I need some larger wood for this thing to see where it really is. It's running a 3/8, 10 pin set up.
