czar800
- 7:17 AM
- Jan 14, 2016
- Ellwood City
Over the years I built a lot of laminated beams. 2 x 10 then 3/4" plywood, glued, repeat.....
I think he wants to rip all the material himself through.
The first thing I would do is a little site work. Cut the ground down level and flat using a spot about 20' out and to the left of the front of the new building as a bench mark.
Then you would have quite a lot more height if I'm reading the ground correctly.
Then use beams for the whole structure. Shed roof style right off the overhang of the garage.
I agree with this. But even with site work it looks to me you will have minimal height.
You will be dropping 2' @ 2/12, plus like 6" rafter height on a 2x8, plus 16" beam. That's almost 4' down.
I'd want more head room.
I'd pick a clearance height, and shed it to where it lands on the roof. Add a support wall under the rafters sitting on the existing plates and run a 2x nailer across to land your rafters on.
When I'm framing a roof onto a beam, I slot the beam on the pitch angle for the rafters before putting it up instead of cutting birds mouths. It locks the rafters in better, and especially on old buildings when nothing is straight, you set your rafter up top while it lays in the slot. Check plumb and straight and nail it home.
Very intelligently done Dan.
Nice work sir
Do they make you put those metal hurricane brackets on the rafter joists there when the rafters are exposed like that ?
