junkman
Crush it
- 6:37 PM
- Jan 3, 2016
- pacific northwest
Would cost more than an aluminum insert ,but saw heads will pay out the nose if the part works better and is shiney.
If you wouldn't spend all of your money on Bag Balm, you could afford to buy saw parts.I have never spent more than $23.84 rebuilding a saw. That's my story and I'm sticking to it.
In my limited experience I think the primary focus for a filler is not to add strength but to simply stay put in the cutouts and perhaps be resistant to oil/fuel.I bet a titanium insert would be light plus stiff
On longer bars stiffness is important, reduced weight bars I have used wobble or flex more than a full steel bar.In my limited experience I think the primary focus for a filler is not to add strength but to simply stay put in the cutouts and perhaps be resistant to oil/fuel.
When drilling a bar for different mounts, you don't want to use high RPM because the bar will actually harden as you work it. Once it's work hardened, you're hosed. If you're going to use a bimetal I would recommend staying at low RPM on a drill press and using plenty of oil. The annular cutter is made for that job, but if you can oil it do it, and still keep the RPMs lower so you don't have to fight the material as much.
I know this was mentioned above, but I don't think a standard hole saw will cut through a bar once, let alone 10 or 15 times. But it would be pretty cool to be proven wrong in this case.Does a good bimetal hole saw cut a bar? How hard are they?
Most recently I was looking through some paperwork for Granberg stuff related to dtilling for an auxiliary oiler and they said stay below 80 rpm.Tim,
When you say, "low rpm's" what do you feel is an acceptable range?
I would imagine keeping the pressure light is a good idea as well.
Should I video my cutting, and have Chris_PA verify my RPM's with his Soundwave Tachometer App?
That slow and you can just count it haha!
Yeah, not setting the world on fire. You might want to start with baking the bread first.Good grief! 80rpm's......I'll hang a 5 lb weight from the press handle, set a bottle of cutting oil to a slow drip, and go fix myself a sandwich....
Laminated bar?I actually try to plasma cut holes in an old bar tonight and it went pretty poorly. The layers screwed up the cuts.
Yeah. I was just testing..Laminated bar?
I assumed that Jon was planning on drilling solid bars.
Philbert
