ECHO Echo, Echo, Echo
sawfun
4:00 AM
Portland Oregon
The saw pictures is a 1001: The 1201 is a bigger Saw physically, & the clutch cover is larger.
Yes I know of the LARGE differences. I was trying to state that if s newer currently produced saw does not have a chain brake, then I kinda doubt that an older model (significantly different) saw would.
hseII
AKA - Karenberly's Husband
7:00 AM
West Georgia
I know they were offered on the 900EVL & I assume there was a Canadian version of the 1001EVL with a CB.
That’d be something to see.
sawfun
4:00 AM
Portland Oregon
Thanks for the info.I would like to know when Echo discontinued the 900evl, the 1001vl, and when the 1100 started. Acre's site does not show this info.
FergusonTO35
7:00 AM
Boonesborough, KY
All the 1001's I've seen had just the white plastic handguard common to Echoes of that vintage. Seems like Echo didn't equip all their USA market saws with brakes until after the new designs with the vertical cylinder came out. At first I thought the 1001 was a Canadian model because the metal handguard looked like a brake handle that was added on later to meet the requirement.
Hoggwood
4:00 AM
Above the 49th
The 1001's never came equipped with a chain brake. Made from '76-80', they only sported the tube steel finger guard. It usually snapped off in short order.
Sawfun's looks like an early ('76?) model given the pentagonal shaped fuel and oil caps and the rear handle design. Later caps were round and the rear handle was redesigned to incorporate a hand guard and operator presence lever.
My dad's 1001 that he passed along to me a few years ago. He bought it new in '79. Presence lever was removed. You can see the remains of the snapped off guard still mounted to the handle support.
On a side-note. I picked up a relatively rare (for these parts) 452 with chain brake last week. Needs some new plumbing and it will be good to go. Pretty low miles.
Echo CS-452VL May 2018 (2).JPG Echo CS-452VL May 2018 (3).JPG Echo CS-452VL May 2018 (5).JPG
sawfun
4:00 AM
Portland Oregon
Hoggwood, thanks on the 1001 info. Nice looking pair of Echo's there.
Battle Cross 2
7:00 AM
Southern PA
67L36Driver
6:00 AM
Freebie from a couple weeks ago.
Pops on a prime. [emoji106]
Stubnail67
7:00 AM
florida
best bet is a blown up one with the parts you need oem parts will have you more then you can sell it for....they hardly ever blow up ... hit you local echo dealer they sometimes have parts saws....or be patient and a carcass will show up on ebay for ten bux and 20 shipping....
67L36Driver
6:00 AM
Browse evilbay for Echo parts is depressing. New parts are stupid high as are used stuff.
