LittleLebowski
I’ve cleaned it up well, don’t see any obstructions, and with the oiler wide open, I get a dribble. What should I be looking at?
What's the pick up screen in the tank look like?
Whats your bar oil to gas ratio?
Tank of bar oil to tank of fuel?
This IPL may help you ...be sure the worm drive is being turned as the tips can get worn so they dont get taken round by the clutch drum. Remove that feed pipe to be "sure" its not got gunk in the strainer... also gives you the chance to check for leaks. Check out the teeth on the pump rod while your about it. Taking things apart at the get go to check things through "Often" saves time in the end I find.Using a good flashlight, it seems fine. I’ve never taken a saw apart before, so I don’t have a complete picture of how it looks, but seems perfect from what I can see.
At max oil setting, it gives me a steady dribble, that’s it.
A healthy PS-6400 should run out of oil prior to running out of fuel with the oiler screw maxed out!I am not exactly sure on the first question, I always make sure to run out of fuel first; I know better than to top off fuel and not top off bar oil. This problem is bad enough that I cannot cut wood, the chain is clearly not getting enough oil, so I have been only using my 421.
Could you elaborate?Don't forget the vent.
+1If you need to see I can pull mine off and take some pictures.
I used three bond on all the fittings, there is a bushing that presses into the oil tank and those leak a bunch. And I added some to the rest and mine oils very well, no leaks. I need to go through my new 7300 and do the same.
