Dirty Wood
Duce
11:06 PM
Roscommon, MI
Philbert
Chainsaw Enthusiast
10:06 PM
East Dakota
Mr. Chain Guru @Philbert , You like my chains?
If they cut, they cut!
Lots of ideas for muddy logs: even brushing off dirt before cutting.
Peeling bark off green trees.
Maybe even a bristle brush on an angle grinder?
OPā€™s suggestion seems to work for him. Perhaps, with a large number of cuts, you dedicate one saw/chain to cut through the muddy bark, and another to cut the cleaner wood?
Philbert
5:06 AM
Has anyone noticed oregon semi chisel being prone to cut crooked? Dry dirty euc.
Oregon makes semi chisel?
Huh! :thinking:
I have Dolmar branded semi chisel, Oregon makes it. šŸ˜‹
You are doing something wrong during sharpening!
Or, Your chains DL's are bottoming out in the bars groove!
Worth checking.
Loony661
Stock chainsaws suck.
10:06 PM
Winona County, MN
Philbert
Yes absolutely. There are a lot of ways to go about this. In my example, Iā€™m just showing that it can be done efficiently with a little forethought.
This is how I make my living, so Iā€™m certainly looking for the fastest, most efficient way to get it done. Swapping chains takes time. Sharpening chains takes time, and uses up chain life. Iā€™m certainly not going to peel bark, walk all the logs and scrub them with a brush, etc. But those methods absolutely work to get the debris off the logs.
How else do you guys go about cutting dirty wood?
davidwyby
Tree felling enthusiast, 288 collector
8:06 PM
Extreme Southeast CA
Old bar, did you re-dress bar when installing new chain?
I checked it. Swapped back to skip full chis and it cut fine. I had hit debris and touched it up with a file freehand. I had to either go through and do all the cutters and rakers with a husky roller guide and measure to length or my stihl USG grinder. Never had so much trouble with tiny imperfections or inconsistencies having such a dramatic effect.
@Wilhelm Oregon Duracut aka multi cut
Inferior to stihl RM
Loony661
10:06 PM
Winona County, MN
I bought some of the triple chrome plated Oregon semi-chisel 2 years ago to try in dirty conditions and I really dislike using it. Iā€™ve tried different sharpening angles and depth gauge heights, and I just can not get it to perform. I just tried it again the other day on a couple logs and the only way it would cut was dogged in - and thatā€™s in green Red Oak!
5:06 AM
... Oregon Duracut aka multi cut
IMHO, the fancier the products name the worse its performance!
I haven't purchased Oregon chains in over a decade, so my experience may relate to old stock.
Just suck it up and try Husqvarna X-Cut, if You haven't already.
It is superior to Oregon LGX/LPX.
davidwyby
8:06 PM
I feel better now. Only way I could get it to cut well was to put so much hook in it that it was delicate despite the ā€œtriple chromeā€. I have a theory from looking at Oregon and stihl chain. 10Ā° down on the file puts the working corner up where it should be vs. down on the side how Oregon is. Unfortunately my USG has offset but not tilt.
@huskihl also pointed out the stihl RM is less rounded. Itā€™s interesting how different cutter geometry translates to different shapes/angles even when ground at the same settings on my USG.
My plan for these chains is to put a durable grind on them, drop the rakers, and let the 3120, the Euc, and the CBN wheel Kill them.
Squareground3691
11:06 PM
New England
I did the same, more aggressive hook ,
Moparmyway
Its just a saw
11:06 PM
In a meeting
* I'm not one of those that think safety chain cuts significantly slower than std...but I DO hate how it gets in the way of my progressive raker guides.
Use a digital angle gauge on a small piece of flat steel (1x4 or longer).
I get that the progressive works great, I use it.
But for race chain or ā€œothersā€ that the progressive doesnā€™t work on, itā€™s pretty easy and quick, super accurate too
Loony661
10:06 PM
Winona County, MN
Iā€™ll have to try even more hook and see what happens.
