Redfin
Meh...
- 11:15 AM
- Dec 24, 2015
- Central Pa
Good stuff fellas, good stuff.
Dan, these pics may help us all understand.Ok that makes sense.
Earlier I think terry mentioned the transition holes acted as air bleeds until the butterfly opened. This is what I don't get. I thought you meant you drilled another hole down to the fuel reservoir....
Do these holes actually bleed air into the carb body?
View attachment 26182 View attachment 26183 View attachment 26184
Rich, I saw in the tech section under carburetors that your now having to work with Zamas that aren't 'twin jet'. Bugger, those were easy to mod, hopefully you will get your head around the newer type carbs.
Here's something I've run into when modding the 460 carb. I like the 460 carb because it has the largest venturi of the HD series (17.45mm) plus an offset main discharge nozzle - I think it will flow the best of that range of carbs.
The 460 carb is an EPA carb. I had originally thought that the small jet in the carb was a restriction on the low speed circuit - it isn't. Turns out it is an 'auxilliary' jet like on the twin jet Zamas. Unfortunately, it sits too close to the throttle plate and can cause problems with the idle, especially when it gets drilled larger (I don't know what the max size should be...)
Then I thought "where in the Hell is the source of fuel for the low speed circuit??" - I found it, I had to punch out the main discharge nozzle. You wouldn't believe it, the low speed circuit takes it fuel from the high speed circuit. There is a passage way drilled into the nozzle tunnel that leads to the low speed circuit.
I plugged the passage in the nozzle tunnel with some GB Weld, put the nozzle back in and then drilled a 1mm hole in the wetside just in front of the low speed needle seat in order to feed fuel to the needle. It completely changed the way the carb worked, it went pig rich immediately.
Not only is the idle more stable, but the max RPM is more stable. I'm going to do some more work with the metering springs, but I think I'm on the home stretch with this carb.
I thought you might like the information about where the low speed circuit picks up it's fuel as you may run into the same configuration in other carbs.
Happy 4th everyone,,,, If you know a veteran,,, Give them a hug or handshake, and tell them thanks,,, cause I sure do!!!Lots of newer carbs are like this Terry. The 3120 carbs I do are the same way. Everything goes thur the main jet, to the metering nozzle area, then on to the low side and welch plug area.
My friend Harold, he did 3 tours in Nam, says that I am the only one who ever sent him a Veteran's Day card.
I did two hard tours in Nam and all I got was crap from people when I got back. It was 'politically correct' to act that way back then, now it is politically correct to say "thank you for your service". - I feel like telling those people to go fork themselves.
I'm going to play around with this 460 carb and see where I can take it. I also have an HD-5 that appears to be designed the same way. We may be able to come up with a set of general mods that can defeat the EPA geniuses.
I use sir and mam everytime I speak to someone, how often do you hear that anymore?In my family it was never politically correct to be rude to anyone, and we were taught to respect our elders too. Once as a child my dad and I were walking into a store. On the way to the door we passed a group of older guys sitting on a bench in the shade of the building. I was in the lead, and only had candy on my mind. I never spoke a word to those guys, but dad said hello as we passed. Once we got thru the door, he slapped me across the back of the head. What did I do wrong? Then and there he taught me to never walk past my elders without acknowledging them, to always at least say hello, or ask if they were doing well. Those sort of lessons are sorely missed in my eyes. Maybe manners are making a come back Terry. Maybe that's what is changing....
I hope you do figure out those epa carbs. They can be a real pain to use on larger saws. The 395xp carbs too, I've tried using them on 65cc engines with mixed results......
Everyone has the time... most only choose to worry about themselves.nobody has time to be kind anymore.
