- 4:37 AM
- Dec 29, 2015
- Strong Island NY
So what's the impulse line do?
No shït. Just what I was saying before you told me that the fuel line supplies fuel.The impulse line is providing an AIR pressure change on the side of the pump diaphragm to move it and pump fuel through the fuel valves on the pump diaphragm.
that is why they all have that "neck" in there and will not run w/o it
ExactlyOK, what happens at idle? There is so little suction at the main fuel nozzle that they have to put a valve in the nozzle to keep the air from being sucked back into the wetside. - Essentially, both the low speed circuit and the high speed circuit in the carb will be sucking fuel from the wetside. At idle the amount of fuel that gets sucked out of the wetside is very small and the metering diaphragm needs a bit of help to ensure it has an appropriate amount of fuel for the idle mixture - so you have the pump diaphragm to ensure it gets topped up - stable idle and such.
The low speed circuit has it own fuel curve that is different from the venturi fuel curve. The object of 'blending' those two fuel curves together gives you the overall fuel curve for the air flow through the carb. The low speed circuit is in the straight section and has small fixed orifices that max out fairly quickly. The high speed circuit is located in the venturi and becomes more active as the air flow increases. - Blend the two together with the air flow and you get a more optimum fuel mixture over the powerband.
The idle hole is in front of the throttle blade, and the two holes behind that blade act as air bleeds at idle and supply fuel at mid throttle?
I can have a saw tuned perfectly on the H, then play with the L needle and get a totally different high end tune.
On some saws, they load up with fuel at idle if set too rich. But leaning them out causes awful throttle response.
So what you happen if you put a metering spring in with greater pre-load? - The higher pre-load causes a resistance to flow at idle that works just like lowering the float level in an old float bowl carb. Essentially, you lean out the idle, but you keep the same low speed circuit flow that you wanted when cutting wood.
EDIT: The next time you get into that situation, try putting a few shims under the metering spring.
The restricted L needle flow you get by shimming or putting in a more resistant spring, thus "Mechanically Leaning " down the mix would require the "Idle" screw to change reducing the increased RPM , and moving the butterfly slightly more closed (I presume ). That is going to reduce even more air flow available through the carb at Idle speed ....this is not a problem as you see it ?So what you happen if you put a metering spring in with greater pre-load? - The higher pre-load causes a resistance to flow at idle that works just like lowering the float level in an old float bowl carb. Essentially, you lean out the idle, but you keep the same low speed circuit flow that you wanted when cutting wood.
ROFLMAOThat's the job of that long bit of hose with the filter on the end of it inside the tank, it drops down with the fuel when you change position.
My interest is also with the Stihl 024 026 saws as they can prove a little tricky on the idle with some carbs.
Tricky all this as there are many things to consider . Lower delivery start point volume from the idle hole is what im assuming will be the result , but until you open the throttle from its resting position to get into the transition side you are working on the fuel available . So i assume less fuel meant less air needed to maintain idle speed thus the gap around the butterfly would be tighter and less air movement through the carb.I think what he means is by mechanically leaning it, you can then richen it back up with the L needle, essentially providing more fuel for transition, better spool up, without it loading up at idle.
