Cerberus
Cerberus the aardvark, not the hell-hound!!
- 10:50 AM
- Jan 20, 2020
- Florida (tampa area)
tl;dr -- if your carb's Idle adjust screw just fell-out & got lost, but you have thousands of on-hand bolts & found one that "fits perfectly" and works, are you being dumb using it / should you still just bench the unit til you get the Walbro brand screw? (NOTE: this idle-screw doesn't work by simply pressing-into a plate upon CW turns, it's unique it has a perpendicular worm-drive-gear in the hole so when you bring the bolt in/out it moves that, so I'm guessing that "fits & works" isn't good-enough here....but also have no idea what part# to get from Walbro, have googled and got nowhere..
My carb's idle-adjust screw fell out I imagine it's because I was using the saw for notching a large Pine I felled, I was tuning the saw so I had the carb-screws-plug off (which would've prevented this!) and was doing some on-job tuning, anyways I bucked a couple logs just fine, adjusted tuning, then felled the tree & began bucking, on my 2nd or 3rd buck it felt funny so I looked at it and found it was missing its Idle-adjust screw!!
Oddly enough, saw still works!! Go Walbro (and Mastermind, as this is his build except the top-end which I had to rebuild after I broke his top-end :/ ) But I do have to give it a stab of gas on startup, as-well-as keeping throttle at like 5-10% while it warms-up for 1-1.5min, after that it works (though it will fall-out from idling, but you could use it & go through a job with it)
Anyways I do have a replacement-bolt that's the "right size" IE width, pitch etc, but when I looked closer at the hole - and saw it was true/plumb wtih the carb - I realized the 660's idle-adjust doesn't work by pushing-into a throttle plate, but instead there is a perpendicular worm-drive-gear on the bottom side of the beginning of the Idle Adjust hole, so the screw's insertion/removal from the hole is driving that worm-gear....
My replacement bolt feels good but I'd hate to find, a week later, that I ruined my Walbro carb by using the wrong screw!!!
Thanks a ton, and if it helps this is a pic of the hole & the way I was seating-to-test a bolt
