livemusic
- 1:59 AM
- Jan 22, 2016
- NW Louisiana, USA
This is an ms200 (rear handle) and I can't freely turn the chain tension adjustment screw because there is a steel plate thingamajig turned into the hole where you insert the screwdriver. I don't recall having the problem in the past but I have not run it for maybe a year other than cranking it every once in awhile just to run it some. Seems to me this metal part is made into this plastic clutch cover during manufacture such that you can't replace it other than buy a whole clutch cover? How could I turn this? The edges appear to be boogered up into the plastic such that it is not going to move without a trick. Or else I just booger it up beyond hope. Is there a solution? I did try to move it but got nowhere. Pics attached. Front image, I can't figure out how to make it display correctly, need to turn the image 90 degrees so it would be 'right side up.'
First image is front view, 2nd is back view.
