XP_Slinger
They’re Just Saws
- 10:35 AM
- Feb 9, 2016
- Central NY
It looks awesome to meIt's an 85', 350 auto, not a show truck but it holds its own around here in the rust belt.View attachment 66737
Thanks man, appreciate the compliment.It looks awesome to me
You are very welcomeThanks man, appreciate the compliment.
I have heard you can't use a tack on these saws but I think my tiny teach worked on my 181 but that had been a long time ago and my memory just works part time lol288 question; Why did my tach go crazy when I tried to read the rpm before I tore the saw down? Is it because the 2 coil set up screws with the ignition signal?
Shoot me a pm might be able to hook ya up.Seems like I've used my tiny tach on my 288 before. If XP Slinger doesn't want one, I may be your huckleberry.
You going to use one of these?
Sent from my SM-G935V using Tapatalk
My 930 has exact same ignition setup as 288 in it and my tach works, what kind of tach do u have ?288 question; Why did my tach go crazy when I tried to read the rpm before I tore the saw down? Is it because the 2 coil set up screws with the ignition signal?
Not even 100% sure what that is...lol! The beginnings of a velocity stack?You going to use one of these?
I have a Wireless FastacMy 930 has exact same ignition setup as 288 in it and my tach works, what kind of tach do u have ?
I'd like to see one installed. I have an idea in my head but I'm not sure if it's correct.I sure will.
I don't have a saw to mount it on but I will post pics when I finish it . My stock for a mandrel was too long so I got to messing around with it I was going to have to cut it anyway I will get it finished up soon.I'd like to see one installed. I have an idea in my head but I'm not sure if it's correct.
