NIdaho
New OPE Member
- 12:44 AM
- Apr 14, 2022
- North Idaho
I should probably mention a few facts about the saw.
Long story short, I ordered the oil hose, oil pump and the chain guide plate (has the opening for the end of oil hose and the bar mounts against it) as these are all the parts that I figured might have a part in an bar oil leak (that is everything between the oil tank and the bar itself). When all the parts came in, I disassembled the clutch side and couldn't see any problem with any of the parts. I went ahead and reassembled it using all the new parts (and bagged up all the old parts as possible spares). Everything looked great, so I went ahead and filled the oil tank with bar oil and set the saw on some cardboard. the next morning there is a small pool of oil on the cardboard! Like I said, I put oil in the tank, but I never even started the saw so I am thinking that the oil hasn't even gone thru the new oil pump.
So after being really frustrated with the saw still leaking I dug into it some more to see if I could figure out where exactly it was leaking (probably should have done this first). First I did some checking to see if it was leaking out of the oil tank vent between the bar mount bolts. After checking it out, I couldn't find any evidence that that was the cause of the leak, and I was seeing more oil near the gasket between the 2 halve of the crankcase/oil tank. I then took the wrap handle off and undid the anti-vibration mounts so that I could move the control handle/gas tank to get to the bottom of the crankcase. Once I got that far, it didn't take me long to figure out what was going on -- someone used the WRONG SCREWS when they assembled the full wrap handle onto the saw.
You can see the 2 spots on the bottom of the crankcase where the screws have been wearing holes thru the case.
So now the Question is where to go from here?
This was a definite mistake by someone of using the wrong screws at this location.
Like I said the shop I bought it from is out of business.
The factory warranty has expired so I am doubtful that Husqvarna will do anything for me.
IDEAS? SUGGESTIONS?
Thanks,
Bob
- It is actually a 562XPW (Wrap Handle)
- I bought it brand new from a dealer in early 2016 (late winter/early spring) as an upgrade to my 266SE and L65 saws (the L65 was my dad's 1'st Husqvarna and still runs GREAT))
- Serial tag shows it was built in 2015
- Its not been used commercially (just here on our place in northern Idaho and our lake place in western Montana)
- Dealer is no longer in business (long time local shop that loggers in the area used and has since gone out of business as the owner retired)
IDEAS? SUGGESTIONS?
Thanks,
Bob
