FergusonTO35
- 7:08 PM
- Jul 9, 2017
- Boonesborough, KY
Hmm, my Marlin 1895 .45-70 with trapdoor level loads scratches my big bore itch just fine!!
.280 Remington ftw. With a 338-06 and maybe a 8mm Remington Mag.300 win mag is the ultimate round if ya ask me.
You fellas can keep the semi autos too. I'll take a bolt every time
Locust Cutter- on your 629, carefully examine the area where the little nub on the end of the ejector star enters the frame. This nub pushes back the cylinder release bolt when the cylinder is closed. If it only enters part way, the bolt won't go back all the way and can lock the hammer, thus jamming the mechanism. Check for burs, rough spots, and make sure the hole in the frame is large enough and not dragging on the nub. Next time it jams, pull the cylinder latch back all the way and see if the jam disappears. If it does, I bet that is your problem.
Another thing: does your revolver have the key lock in the frame? Recoil can cause the lock cylinder to turn slightly, jamming the mechanism. I disabled the lock on my 637 by filing off the little stud on the flag that locks the hammer and erasing the "LOCKED" lettering on the flag. I would never use that stupid thing anyway, when my guns need to be locked up they go in the safe.
All excellent cartridges for the re-loader with the .338-06 particularly interesting me in either a E.R. Shaw, Shillen or Bartlein barrel at least 24"....280 Remington ftw. With a 338-06 and maybe a 8mm Remington Mag.
I would be comfortable carrying it anywhere with the ammo available today. It's like the 1911. It's been around that long for a reason.Absolutely! 111 years old and still gets it done
We all like our favorite calibers, but at the end of the day the good old 30-06 with a good bullet and shot placement will handle most anything in the lower 48.
Yes. There are very few problems that cannot be solved with a good Marlin 336 and a Dolmar 5105.
