- 8:12 PM
- Dec 29, 2015
- Ontario, Canada
10-4 thanks for that Mike!When you tighten down the cylinder just make sure the piston is at BDC. This will help align the cylinder.
This is a 046 cylinder that's been clearances for a 044 hybrid build.
When you tighten down the cylinder just make sure the piston is at BDC. This will help align the cylinder.View attachment 83839View attachment 83840View attachment 83841
First I had to grind the embossed numbers off the jug. See #49 for details. Then just grind/file a little from the lower jug fins on the ignition side. See @Canadian farm boy 's piccie here #101 . I think with mine I ground a little less than Mike did. You don't need to do much. Just keep hitting it till it drops on and you can slide it about a little on the casing flange.Do you have any pictures of any other modifications needed to fit the 046 cylinder on the 044? It looks like some have posted the case might need some grinding as well as the fins on the top of the cylinder so the cover fits.
Thanks for the info. I was going to do the same but use a 460BB 54mm cylinder. I don't have an oem cylinder to use and I thought the 54 mm piston might need some case clearance on the inside. I don't have the kit yet, should have it next week.First I had to grind the embossed numbers off the jug. See #49 for details. Then just grind/file a little from the lower jug fins on the ignition side. See @Canadian farm boy 's piccie here #101 . I think with mine I ground a little less than Mike did. You don't need to do much. Just keep hitting it till it drops on and you can slide it about a little on the casing flange.
You shouldn't need to grind the case to actually drop the jug on....I was case grinding so that my early 044 (10mm wrist pin engined) casings would receive a 12mm wrist pin crank shaft (MS440).
I *think* I'm good with any clearancing issues right now - will report back later on if any thing else materialises.
Ha ha! I'm kind of inclined to take this an inspirational speech..........but I'm puzzled as to the use of the clay.Stop grumbling and keep going. This part of the build. Your right on point! Clay helps sometimes. Pack the case top with the piston down in. Drop the jug down tight as you can. Pull jug. Pull the clay as your cutting it away from the base and piston. Check the piston gap. Wiggle wiggle grind and file.
Hmm.... when I fitted the piston to the crank (without attempting to install the jug) the piston seems to have plenty of clearance, though it's hard to appreciate where exactly it wants to be with the jug down. (Perhaps that's what @Lightning Performance meant with his earlier reference to clay?)Thanks for the info. I was going to do the same but use a 460BB 54mm cylinder. I don't have an oem cylinder to use and I thought the 54 mm piston might need some case clearance on the inside. I don't have the kit yet, should have it next week.
Wow! Yeah maybe.....Now you need a proprietary Two Idiots Logging hybrid muffler spacer designed by yours truly!
I think DDave sells em
View attachment 84287 View attachment 84288
Hello again,Had an early 10mm 044 that would not clear a 460 piston dropped in on the rod.
Not really a benefit but more of a necessity.Wow! Yeah maybe.....
Explain more about it, my friend, what are the benefits?
Since it is very difficult to tell accurately just where the piston skirt will end up at clearance wise to the case I shot for .025 clearance all the way around.
