Your favorite sealant to use on saws, and why
Mark71gtx
8:47 AM
Fuquay Varina, NC
I have seen several posts here and on other forums about different sealants used on chainsaws. It would seem that there are many different ones to choose from. I am interested to see what is your favorite, and why? What brand will you never use again, and why?
So far I have only used Permatex Motoseal. I have had good luck with it so far. I chose it because I can pick it up readily at virtually every auto parts store locally.
jmssaws
Banneded
7:47 AM
I've used derco for a long time,I've never had it fail and it smells great.
I rarely use it anymore,if I can at all I use a gasket.
Genius
First member of ASlite to receive a infraction
8:47 AM
Uncle Willys basement
I use Motoseal, it is readily available.
I do want to try Dirko when it comes time for a new tube.
jmssaws
Banneded
7:47 AM
I get Dirko from the stihl dealor for 13$ a tube,used it on mufflers and bases with out any problems. Good stuff but very stinky.
Steve
Excellence!
7:47 AM
I use motoseal and locate 518 depending on the situation. I like 518 for base gaskets because you don't have to rush to get the jug down like motoseal. Also if you use too much on a base gasket the uncured stuff hanging out in the transfers gets blown out the muffler. I like motoseal for clam shell engines and sealing impulse nipples.
jake wells
no longer here
7:47 AM
ky
i use loctite 518. i also use permatex no# 1 or 2 gasket maker.
8:47 AM
Is Permatex 51817 Anaerobic Gasket Maker basically the same stuff?
d.l.d
7:47 AM
Arkansas
1194/1184 because it hasn't let me down yet and i haven't found anything i like better.
Carbine
8:47 AM
Ohio
I've used permatex copper with good results (I've seen some pretty reputable guys on another site use it), but recently picked up some loctite 518 from all the talk.
8:47 AM
I used that spray on paper gaskets if I was making one. Lay it out and spray it and let it dry good on both sides then spray lightly again and assemble.
P.M.P.
Stiff Member
8:47 AM
Michigan
I have some Hondabond 4 like it bcause that's what on hand.
