Yet again .... JMSSAWS strikes
Sleeper
7:57 AM
United States
Learn stuff almost every day. Interesting how they balance the crank... never seen that before. None of my Macs were shaved balanced like that.
Another book I think everyone interested in engines (and the history of outboards and inboard/outdrives/sterndrives) should read is "The Legend Of Mercury" by Jeffery L. Rodengen
Gives the whole story of Carl Kiekhaefer and how Mercury came to life. Great read, just got done with it and learned a lot.
Moparmyway
Its just a saw
7:57 AM
In a meeting
Is it useable Kevin?
@Moparmyway, what does the piston skirt look like?
Does that coinside with your assumption?
The skirts have been mostly polished away, but what happened to that crank, I'm not sure that the piston didn't do that. I've got 4 cranks from 1122's to view, one new and 3 very used. Also have 2 cranks from 1128's. They all look the same, marks from spinning them in a lathe.
The chatter marks are only on this one crank.
I'm certainly not going to try to say that I'm sure, but it definitely stands out
6:57 AM
It would surely have aluminum transfer on it if it was making that much contact.
7:57 AM
My bet is that those marks are from the first time the saw blew up.
We all seem to forget the saw was redone twice.
I'm sure he cleaned nothing after the first wrist pin blew.
Probably lots of crap peening that crank.
Moparmyway
Its just a saw
7:57 AM
In a meeting
Then the good news is that my initial thoughts are probably dead wrong, thanks to Jim, Mike, and Randy. This also means that the crank is fine and I'll be able le to use it without any worries
Thanks men !!
Edit: Could the blown rod bearing have caused the pitting like Doc @drf256 hypothesizes ?
Does anyone have a new crank that isn't used that has these marks ?
I do understand that Jim @Chainsaw Jim has that crank, but it is used, and is it possible that it had an event prior to it being removed ?
6:57 AM
I think the color would be different in any damaged areas.
blsnelling
Friend of the Riff Raff
7:57 AM
Franklin, OH
My money is that it's from the factory like that. The patina is the same across the entire crank.
Chainsaw Jim
Con Artist LLC
4:57 AM
Springfield Oregon
Thanks men !!
Here's a close up of an original 1100cd big end.
That little thread mark spot Al pointed out up above is definitely not from the factory and could not be from anything other than Jason dropping it on a concrete floor on top of a screw or swapping the new unblemished one for the one pictured.
paragonbuilder
7:57 AM
Norwich, CT
It also looks very consistent. And don't forget the piston would only hit the crank in one small area. Not the whole surface. If it was damage, I would think the wristpin bearing parts in the bottom of the case, but you would see that in the case when you split it, and I don't think the motor would have ran but a few moments with all that crap in there.
I'm with Brad on this one.
Moparmyway
Its just a saw
7:57 AM
In a meeting
Cases split, bearings and seals out, new bearings and seal kit on the way (thanks to a very generous forum member). One bearing had some rough spots as you spun it. Good thing here is that this new saw will have new bearings and seals along with a NIB P&C.
More buggered stuff too .......:facepalm:
