- 11:01 AM
- Dec 4, 2015
- In a meeting
No offense Sir,I see how it is......
But if you're goin to mark yer boundaries, you'd better have strong piss
So long as you aint thinkin of grabbin my arse, then we're good bud !!I can't express my gratitude the right way on this forum kev.
Cleaned up muh bench tonight, getting prepped for this 660. Pulled the 288 piston, removed the base gasket, wiled down the case and found this ................
View attachment 85707 View attachment 85708
At least it's only 2 holes that I had to run the tap through
No, he musta been using a dang power driver to start the screws ............ lookat them scrape marks next to the boogered threadsDid he Helicoil it?
What a pro Jason was.Cleaned up muh bench tonight, getting prepped for this 660. Pulled the 288 piston, removed the base gasket, wiled down the case and found this ................
I'll try them Deeter ........Damn that's crazy.
If they don't clean up I'll send you time serts, they are way better than helicoils
Wtfff...Cleaned up muh bench tonight, getting prepped for this 660. Pulled the 288 piston, removed the base gasket, wiled down the case and found this ................
