Worksaw vs Playsaw
exSW
'Cause Thomas is a poopyhead
11:53 AM
United States
How well a saw(or anything else) holds a tune goes a long way to how practical it is for work. If you are constantly retuning you're not producing. Very few things are more aggravating than having to F*CK with your tools.
RIDE-RED 350r
11:53 AM
Blossvale NY
Yes, ditch the limited coil.... FTR Husky limited coils are 13.3 with the exception of the 346NE... Not sure about the 5 series saws. But yes, my two ported saws are still spooling north of the stock limited 13.3 when I tune then for work.
Definitive Dave
Piss Rev Mafia Member
11:53 AM
Central Ohio
A "Work Saw" you would hand to your ham headed brother in law and know it would work reliably for him all day if he uses the fuel you provide.
A "Nice Work Saw" is just as reliable but you would only loan it to a buddy that knows how to run and treat nice equipment, can easily be a ported model built for work.
A "Fun Saw" is the gateway drug to the real dangers - it's the first time you told a builder to "turn it up, make it spicy, please" the first stone on the path to obsession, probably is still a decent work saw but a larger model that brings an involuntary grin to your silly face when you squeeze the trigger even if there is no wood to cut. Compression high enough it might bite you when starting it if you forget that it is a fun saw.
A "GTG saw" is built out of envy at having all of your saws be just a little slower than the fastest of each model at the GTGs. By this point you are reading more chainsaw forums than a thirteen year old boy watches porn, and your wife might be checking into having you committed. The GTG saw probably has some clearly non-stock parts, beyond a muffler mod and timing advance and even beyond port shaping and polishing and setting the squish and running a power tool around inside. A GTG saw may also have a piston from some other model, a coil or carb from other sources and non standard sprockets and chain, heck it might have the wrong cylinder entirely.
A " No Playin' Around GTG Saw" - at this point a mofo has decided to throw all sanity to the wind and embark on the quest for truly fast. A tenth of a second is eternity and saving it is like saving starving babies from certain death. In addition to all of the "normal" modifications A NPAGTGS is gonna have a hand filed chain, oversize sprocket, possibly custom bar, two piece head, hand made pipe in some combination of ridiculous excess. At this point there is no turning back. Bark and Knots are the enemy. All else is forgotten for that few seconds at the cant. This is saw is half-assed reliable, grumpy, stubborn and temperamental. You wouldn't let most guys look at it let alone run it and you make of point of telling guys how much more valuable your chain is than their offspring.
A "Hot Saw" is but a mere step from the pinnacle. It may include any of the following in any combination in addition to all of the above features - energy compounded starter, ,jetted oiler passages, forced cylinder cooling, passage clearance piston, racing piston pin, titanium circlips, nitrous oxide injection, variac ignition coil, manually assembled race chain with features so dang secret I cant even post the ideas here, round row bearing dawg, skeletonized covers and flywheel, low out-gassing tuned racing plugs. It cost more money than a man would ever admit to and is spoken of only in hushed whispers. It is ever so slightly faster than every other saw that you have ever run or run against, You may spend several days indexing the spark plug for peak performance. This build is never "done".
A "Race Saw" is intended to make money and make other saws it's *b-word. Nearly everything is hand built and mostly unrecognizable as a chainsaw until you install the harvester bar and unobtainium chain. You smile when you think of it and grimace when you think of all the saws you bought on the path that eventually led you here.......where few men dare to tread.
junkman
Crush it
8:53 AM
pacific northwest
W
Where does the precious fit in ?
spencerpaving
11:53 AM
central new york
Seems legit to me....well said dave!!
10:53 AM
work saw
ease of starting. would you want to start that saw 50 times in a day?
tuneable not finicky if its foggy or 10 degrees warmer or cooler
driveable well mannered saw.
im looking for a good idle I squeeze the throttle it goes wot. let of it goes to idle and set it down it idles for as long as I want.
I can cut continuous and not have to fatten it a little because of heat.
would you hand the saw to any saw runner?
Yes....yes....yes.....
tl;dr
Dave is one eloquent basterd.
Well......he is a bastard. lol
11:53 AM
Play saw. It leaks too much gas to use much right now. Muffler mod doesn't help when it's sitting the wood on fire.
czar800
11:53 AM
Ellwood City
Just a few things come to mind that turn a saw into a play saw.
1. Type of machine work.
2. Pipe
3. Chain
4. Flywheel
5. Removable head
6. Carb
7. Fuel
8 everything dave said.
Definitive Dave
11:53 AM
Central Ohio
Does the burning wood cut any faster?
Ya gotta test it on video with solo-mo to be sure.
Maybe a focused muffler mod that jets the exhaust into the kerf to blow flaming chips out of the cut?
You might be onto something.
Even the leaking fuel could be harnessed to produce faster cut times perhaps :)
Member
10:53 AM
Channel that fuel leak to the focused hole in the muffler = Flamethrower Saw! Burned wood surely cuts faster than regular wood.
