- 5:20 AM
- Jan 17, 2016
I like Weak Sauce and I cannot lie….
Keystone State.
Keystone State.
The 400’s are all c version as far as I’m aware so they all have mtronicDo you know if other markets offered a straight carburetor?
Pretty sure a large percentage of the panels are same as the ms362 which does come in a non c version with regular carbThis is what I was referring to, I don't know if that could be just a general casting?View attachment 311361
Now that makes sense!Pretty sure a large percentage of the panels are same as the ms362 which does come in a non c version with regular carb
Could you get an official weight please ?
I need it for my Diary.
Once again the lower transfers are fed differently than the 362 plus not sure you’d see a gain really since that’s basically what a 400 is. They took the 362 changed the cases so they could feed different style transfers on a larger bore cylinder with magnesium alloy piston for quicker reving. They’re may be the possibility of using non mtronic parts of a 362 to make a 400 standard carb though.Now that makes sense!
I looked at the previous pictures and it looks like the M-tronic has the 2 throttle plate set up?
I guess since it shares parts with the 362 it kind of begs the question, could that be a hybrid?
Me also just saying for the guys that have to play with a screw driver or for a race only set up the parts might work to convert a 400 to carb.I'd 10 to 1 rather have the mtronic.
pack it in loose buddyfree warm hugs inside Jeff… plus candyView attachment 311322
I think it would kick a 562 in the nuts and steal it’s lunch money. Just as well balanced but with more grunt. Definitely moar gooder on the fatigue factor.
@tree monkey has a pm for rotten crotch pics. Plus 462s are for slackers who date guys with names like Kyle and Brenden… the MS400 is where it’s at!!!
Other than price&weight also less vibrations&noise.Other than price I don't know why anyone would buy a 400 next to a 462 on the shelf, they basically feel the same
I’m already gay enough I don’t need gay tips from you.pack it in loose buddy
Let's keep this thread straight mkay?I’m already gay enough I don’t need gay tips from you.
Get bentLet's keep this thread straight mkay?
