Any one running one of these or know someone who is? I think Brad got one for one of his saws. Thinking of trying it out in my 2171 I'm putting together.
From Baileys no longer available. Fits the Following Chainsaws:
Husqvarna 371, 371 EPA, 371 K, 372, 372, 372 EPA
Jonsered 2071, 2171
Important Note Full Wrap 372XP versions come with a 75cc (51.4mm) cylinder after 10/07 Be sure to check before ordering.
Replaces Part Number 503 93 92 71
Bore 50mm
Height 42.3mm
Head Type Flat
Piston Pin 12mm x 36mm x 7.75mm
Compression/Pin to top of Piston 16.65mm
Made in USA
Rings 50mm x 1.0mm Alloy steel, ferrox coated, chrome faced, internally notched. Made in Japan
Important Note: These pistons come with high performance chrome plated rings. They will only work with nickel ceramic coated (Nikasil) cylinders. All OEM and NWP cylinders for this model chainsaw are Nikasil coated. Some aftermarket cylinders are chrome plated. DO NOT USE in chrome-plated cylinders. ENGINE DAMAGE WILL OCCUR
I have one of the original Bailey's Wiseco dual thin-ring pistons in a saw I've been running off and on for about six years. Parrisw machined the jug for me back when he was still into saws. It's been a phenomenal runner all this time. I've fell timber with it using 28" to 36" bars. I guess I can pull it apart and see what it looks like internally.
That's the one I'm thinking about trying. The lighter weight might let the crank live longer at 15k+. Oem mahle is $80 or so. I'll weight a meteor and oem when the meteor get here in a day or two.
I saw that they offered an all black piston for a little less. Honestly the price wouldn't be a deal breaker for me if the performance increase was significant or if it was proven to help the bottom end last longer.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
