Wiseco 372 piston
mdavlee
Hillbilly grinder
1:51 PM
TN
Any one running one of these or know someone who is? I think Brad got one for one of his saws. Thinking of trying it out in my 2171 I'm putting together.
Red97
1:51 PM
MI
Is that the domed "dominator" one?
psuiewalsh
Basement Bodging
1:51 PM
Nottingham,pa
From Baileys no longer available.
Fits the Following Chainsaws:
  • Husqvarna 371, 371 EPA, 371 K, 372, 372, 372 EPA
  • Jonsered 2071, 2171
  • Important Note Full Wrap 372XP versions come with a 75cc (51.4mm) cylinder after 10/07 Be sure to check before ordering.
  • Replaces Part Number 503 93 92 71
  • Bore 50mm
  • Height 42.3mm
  • Head Type Flat
  • Piston Pin 12mm x 36mm x 7.75mm
  • Compression/Pin to top of Piston 16.65mm
  • Made in USA
  • Rings 50mm x 1.0mm Alloy steel, ferrox coated, chrome faced, internally notched. Made in Japan
  • Important Note: These pistons come with high performance chrome plated rings. They will only work with nickel ceramic coated (Nikasil) cylinders. All OEM and NWP cylinders for this model chainsaw are Nikasil coated. Some aftermarket cylinders are chrome plated. DO NOT USE in chrome-plated cylinders. ENGINE DAMAGE WILL OCCUR
jacob j.
Lord of Cargo Pants
10:51 AM
Coastal Oregon
I have one of the original Bailey's Wiseco dual thin-ring pistons in a saw I've been running off and on for about six years. Parrisw machined the jug for me back when he was still into saws. It's been a phenomenal runner all this time. I've fell timber with it using 28" to 36" bars. I guess I can pull it apart and see what it looks like internally.
mdavlee
Hillbilly grinder
1:51 PM
TN
Probably not 4 grams worth of aluminum.
Chainsaw Jim
Con Artist LLC
10:51 AM
Springfield Oregon
I think you can order it directly from wiseco with a set of ceramic bearings.
Brad did a thread on it over on as with a link.
mdavlee
Hillbilly grinder
1:51 PM
TN
I'm not worried about the bearings. I talked with tree slingr and he made his own with ceramic balls.
mdavlee
Hillbilly grinder
1:51 PM
TN
Brads the only one I know of that's tried one. Probably not worth it unless you want to go really wide with the ports
RIDE-RED 350r
1:51 PM
Blossvale NY
$110 is pretty typical for a Wiseco forged piston of that size.
No 51.4mm piston.. :(
beaglebriar
The Peanut Gallery
1:51 PM
Warren Center, PA
I saw that they offered an all black piston for a little less. Honestly the price wouldn't be a deal breaker for me if the performance increase was significant or if it was proven to help the bottom end last longer.
Chainsaw Jim
Con Artist LLC
10:51 AM
Springfield Oregon
The price drop on cylinder kits makes this a tough decision. Though I'm sold. When I buy another piston it will be this one with the bearings.
