Wicked 090
Deets066
AKA Deetsey
12:08 AM
427AC940-F881-4B68-89EA-7A29DE38A400.jpeg 54AFEA42-737E-49D8-BAB7-26F750EE984F.jpeg
Head is off the 090 jug and most of the case is clearanced.
This is where I’m at now. I need a good way to hold the case so I can mill it off perfect with the deck.
Also need to bore the case out to gain clearance for the piston.
11:08 PM
ucm931
12:08 AM
Michigan
Just bust out the 4.5 inch grinder and get on it.
Eh....the grinder has its place, but usually on a jug tho. For precise flattening work like that, I prefer the belt sander with 80 grit. If you eyeball it right, you shouldn't need more than a count of two potato after you touch off.
:sisi3:
Armbru84
Just trying to get by
12:08 AM
Michigan
srcarr52
12:08 AM
Iowa City
11:08 PM
Deets066
AKA Deetsey
12:08 AM
Tall v-blocks (crankshaft v-blocks) with spacers in the bearing bores is how I've done it in the past.
View attachment 227180 View attachment 227179
I like that idea, I’ve got a set of V-blocks. Just have to see if they are tall enough.
I’d like to set it up on my rotary table, I’m not a big fan of a boring head but I’m not totally against it.
Lightning Performance
12:08 AM
East of Philly
If you thread the bases of the V-blocks you can bolt on risers.
